Optima Batteries - Quality Rumors?
Discussion in 'Electrical Systems' started by david.carlton@s, May 18, 2012.
  1. Knuckle Dragger
    15,879
    2,269
    Nov 2, 2002
    Waddell AZ
    Spammer bought it back up.
  2. crash68
    crash68 Member
    52
    Nov 27, 2018
    I have an optima because I feel that I have too with the battery in the trunk on one of my 3 classics. I don't in the other two. I've had it this way for a long time and my optimas have been fine except if they are allowed to go dead like when someone is working on them or something gets left on. I did have one die a little early that suffered a lot of full discharges & resurrections and Summit replaced it for free as it was still in warranty. I was impressed!!
    Obviously, I wouldn't buy them for the $ if I didn't feel that I needed one. I leave that car on a maintenance charge as well when it's home because it does seem to have a gremlin that can run it down in a few weeks. I've never had an issue if they were treated well. They are just hard to get to recover if you run them dead.
  3. DB Z28
    DB Z28 Veteran Member
    616
    75
    Nov 30, 2003
    Fond Du Lac
    I had a Red top and it lasted 12 years before it went out bought a another red top it it was done in 2 years.
  4. tom3
    tom3 Veteran Member
    12,958
    764
    Aug 1, 1999
    ohio
    That'd be my luck too I suspect.
  5. badazz81z28
    18,894
    1,006
    Alabama
    According to Optima....batteries are consumables....if you properly maintain them, they last just as long as any other battery. I prefer a AGM battery....so I use Optima.
    They have a 3 year warranty don't they?
  6. DB Z28
    616
    75
    Nov 30, 2003
    Fond Du Lac
    yes they do
  7. rocket dawg
    rocket dawg Veteran Member
    383
    46
    May 5, 2015
    Grand Rapids Mi
    Here is a good video to watch on batteries, this guy is pretty cool and calls it as he see's it. He does tests on quite a few other car related items. The "performance " air filter test was a great watch also.
    Chevyforever likes this.
  8. tom3
    tom3 Veteran Member
    12,958
    764
    Aug 1, 1999
    ohio
    Couple things. He didn't weigh any of the batteries. Two batteries the same size and one weighs less means less lead/copper/acid. See series 75 batteries from 31 to 38 lbs these days. And it didn't make sense to compare the the silver Advance battery to the other top of the line batteries. The best part of the test to me was the inverter hook up. Those things hit a 12 volt battery hard with any real load.
