Optima Ultimate Street Car Fontana Results
Discussion in 'Custom Works' started by ks71z28, Jun 20, 2014.
  1. ks71z28
    ks71z28 Veteran Member Lifetime Gold Member
    2,150
    52
    Oct 10, 2004
    chico, ca, usa
    So all went well. The only issues we had were a too soft rear sway bar, and one of our BFG Rival tires decided to start coming apart. Our autocross and Speed Stop results weren't what they could have been, but that's what we had for the course that day. The Roadcourse was a lot of fun, and I feel we placed about where we should have. It was an honor to place second in the design and Engineering Portion, which was judged by Steve Rupp, Cam Douglas (optima), Lingenfelter Honcho, someone from K&N, and Larry Calehan from Pro-touring.
    10th- Overall finish
    12th- Autocross
    12th- Speed Stop
    7th- Roadcourse
    2nd- Design & Engineering
    here is a video of the 3 competition events
    https://www.youtube.com/watch?v=-ksxc-fXkVA
  2. fhp1556
    fhp1556 Veteran Member
    111
    Jan 30, 2013
    Highland, IN.
    Congratulations Keith on a job well done!!
    Let me ask you a quick question... What wheels are you running and did you have them powder coated?
  3. ks71z28
    2,150
    52
    Oct 10, 2004
    chico, ca, usa
    The wheels are from one of great vendors and supporting sponsors Vintage Wheel Works. We did them in a Custom metallic almost black color to jazz them up a bit. If you are interested in a similar set give us a call
    thanks
  4. ks71z28
    2,150
    52
    Oct 10, 2004
    chico, ca, usa
    So everyone is aware of the tire issue we had with the BFG Rival, here is an update. BFG has not done anything regarding the issue as of yet. Tirerack, who is the exclusive retailer and distributor of the Rival tire informed me that they have had issues with some of the other sizes of there than my 275/40/18 with the shoulder of the tire delaminating from the tread. Their technicians have received my photos below, and i provided them with my alignment specs and video of the car being run. They haven't gotten back to me as of yet with a determination. Below are pics of the single tire that has come apart. It was a left front. Also is a rear tire that appears to have cuts accross the tread, both rear tires have this and it appears to be as deep as the rubber. I have seen this on other tires we have run on the car in the past and never resulted in an issue. My biggest concern with the Rival tire is the durability of the tire when used in competition, for which it was supposedly designed for. Just a not, the outer shoulder is not worn through, and did not contribute to the splitting of the tire itself. The tire has about 60% tread left
  5. Curves
    Curves Member
    32
    Aug 19, 2013
    Olympia WA
    Keith,
    I read on Lat-g that you may make some changes to your torque arm.
    Can you elaborate?
  6. ks71z28
    2,150
    52
    Oct 10, 2004
    chico, ca, usa
    I can't until we actually make any changes. We also will see if Speedtech is on board with the changes. So far they haven't given much feed back on what we have experienced thus far. It works, but i think it can be improved in several ways
  7. Curves
    Curves Member
    32
    Aug 19, 2013
    Olympia WA
  8. ks71z28
    2,150
    52
    Oct 10, 2004
    chico, ca, usa
    That's a lot of work to put that thing so close to the ground! I don't care for how he made the mounts to the subframe connectors, but otherwise that is what i will likely do to the front X member
  9. Schubitzky
    Schubitzky Veteran Member
    342
    15
    Mar 10, 2003
    Maryland
    did you ever get an answer from tire rack or BFG on the problem with your tire? I wanted to get rivals for next season to replace my sportcomp-2s. thanks.
  10. ks71z28
    2,150
    52
    Oct 10, 2004
    chico, ca, usa
    Bfg didn't do anything but tire rack sent me a new tire. I spoke with BFg at the Portland event and they will be updating the compound next year which will effect tire wear but should bring it to a higher level with falken
