Ordered new wheels hope no mistake
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Mwilson, Apr 3, 2018.
  1. Mike (Naples)
    Mike (Naples) Member
    33
    Jul 17, 2016
    Naples and Asheville
    My rear wheels are 9.5" wide with 5.25" of backspace. That means they're 4.25" off the rotor hat. The tire sits about 1" in from the fender lip. Yours will be protruding about 2" more than mine.
  2. Mwilson
    Mwilson Veteran Member
    18,569
    132
    Sep 14, 2004
    Raleigh / Holly Springs, NC
    its 6 1/4" with the new wheels and I measured my current 10" wheels they are 6" from mounting face so it's only going to be 1/4" different, I think offset is more critical with tires that have less sidewall? In the photo the tape sticks through the hole and hooks to the mounting face of the wheel
    4 backspace 10 wheel 79 camaro.jpg 4 backspace 10 wheel 79 camaro-2.jpg 4 backspace 10 wheel 79 camaro-3.jpg
  3. Mwilson
    18,569
    132
    Sep 14, 2004
    my tires sit about 1/2" in from the fenderlip at the tread now
  4. Mwilson
    18,569
    132
    Sep 14, 2004
    If I had a 295 or larger the tire would definitely stick out
  5. Mwilson
    18,569
    132
    Sep 14, 2004
    its actually 6 1/4"
  6. largestar
    largestar Member
    49
    9
    Nov 21, 2017
    how about some video of you yanking the wheels coming off the brake :)
    Mwilson likes this.
  7. badazz81z28
    20,721
    1,416
    Alabama
    ^^ I used public math. An advertised wheel at 15X10" is 11" wide lip to lip. If the back space is 3.77" the other side is 11" minus 3.77" = 7.23"
    Your wheels do stick out a good bit. Is the suspension stiff enough to keep the wheel from hitting the fender lip?
    Here's mine with a 18X12" with a 335mm tire.
  8. Mwilson
    18,569
    132
    Sep 14, 2004
    335 is a massive tire!! I see what your saying but my tire is still actually in the fender now, suspension is pretty stiff I'll find out when they get here if not im ordering some 15x8's not alot of choices with this wheel unfortunately
  9. Mwilson
    18,569
    132
    Sep 14, 2004
    supposed to het the track this sunday so I hope to have some wheels up video
    largestar likes this.
  10. badazz81z28
    20,721
    1,416
    Alabama
    I just would hate to see your tires get damaged with suspension travel or worse the fender.
