Outer Rocker Panel Replacement Help
Discussion in 'Body Restoration' started by 71smalbloc, Apr 5, 2020.
  1. Happy_Dan
    Happy_Dan Veteran Member
    1,038
    247
    Sep 13, 2013
    New Boston, NH
    I replaced the driver side rocker on my car. It was AMD.
    Totally agree if in doubt and if there is bondo, then go ahead and replace it.
  2. rotinrob
    rotinrob Member
    69
    22
    Oct 2, 2018
    Plus you can clean the inner part of the rocker much easier. Epoxy the inside of both panels and use some sort of weld through coating on the seam. Happy Dan how did you like the fit of the AMD rocker? My chevelle will need extensive surgery and was wondering what to buy.
  3. Happy_Dan
    1,038
    247
    Sep 13, 2013
    New Boston, NH
    It seems to me that no matter what you buy, it needs some kind of messaging but the AMD fit pretty well.
  4. rotinrob
    rotinrob Member
    69
    22
    Oct 2, 2018
    Yeah My car used most all GM metal, I bought it back in the early eighties. And that needed some work as the dies were not as crisp and they had been sitting in warehouses forever. The original poster needs to study your support structure. He will need something like that to save his car.
