Paint Chips....how best to fix
Discussion in 'Body Restoration' started by Henrykjr, Dec 8, 2019.
  1. Henrykjr
    Henrykjr Member
    48
    Dec 21, 2000
    Orlando, FL
    Hey guys,
    My 79 Z-28 painted in base coat / clear coat #11 white has some chips on the fenders I need to repair.
    What is the best way to either have this done or do it myself. I know there are some pretty good paint chip guys out there but I cant seem to find anybody here in Central Florida.
    At thr same time I've looked at the Dr. Color Chip stuff......it has mixed reviews.
    Can anyone help?
  2. G72Zed
    G72Zed Veteran Member
    1,529
    468
    Sep 8, 2015
    Find a good paint store and have them mix up 4 to 8oz of the 1979 GM code 11 in single stage, like Axalta formula 5338N in ChromaPremier. Buy a small amount of the matching activator and mix accordingly. Use a fine touch up brush, only mix a thimble full at a time as it will harden.
    GoldenOne7710 and Smokey15 like this.
  3. GoldenOne7710
    5,053
    576
    Jun 23, 2004
    Athens, GA
    My painter is getting ready to address some chips on the very front edge of the doors of my car. His explanation was nearly identical to the above method.
  4. COPO
    18,802
    1,204
    I had Napa make me a rattle can with my code and I either tape up the area (chip only) or I spray a bit in the lid and use an artist fine brush to apply into the chip. I layer the paint high enough to sand. I use a paper binder hole punch for my sand paper and 2 way tape which I stick on the end of a pencil, eraser end. Then I wet sand in circles with 400, 600 then 2000. I don’t bother with clear on small chips. Then I buff it.
    dcozzi likes this.
  5. G72Zed
    1,529
    468
    Sep 8, 2015
    ^^ nice option, but a lot of work for the end results. The Napa cans are generally machine enamel 1K, and looking at the ultimate durability with moisture sealing without the buffing the activated Single Stage is the best option for solid colours, pearls/met. go with base coat and good activated clear if possible.
    If you don't have small artists brushes, you can make your own with masking tape, easy and you can make 100's with one roll of tape.
  6. COPO
    18,802
    1,204
    My paint is Centari which is acrylic enamel.
  7. Coadster32
    1,784
    179
    Oct 2, 2013
    Milford,CT
    If it has metal flake in it, brushing won't be an option. It lays differently when sprayed then being brushed.
  8. G72Zed
    1,529
    468
    Sep 8, 2015
    Wow Centari, that brings back memories!! Started painting on that system, and Lucite LOL. Keep your old paint safe, can't get that anymore up in Canada.
    Correct, most Pearls & Metallics will dabb darker, but OK for touch up (with clear), air brush by a pro is best, depends how fussy you are.
  9. EVILFACE
    EVILFACE Veteran Member
    151
    34
    Sep 6, 2013
    Yukon, OK
    I've had success with Dr. Color Chip on smaller chips.
  10. COPO
    18,802
    1,204
    Still have the paint job from 1985. Centari with clear on top.
    mrfleet12 likes this.
