Painting a 1981 Z28?
Discussion in '1978 - 1981 Specific' started by BradyJack, May 22, 2020.
  1. BradyJack
    BradyJack New Member
    Apr 25, 2020
    Hello, I am just wondering what the cost would be to paint a 1981 Z28 with t-tops? It would be a full body paint job in white. If anyone has had to paint, please let me know what you paid.
    Thanks
  2. badazz81z28
    17,814
    711
    Alabama
    $10K...How good do you want it? You can get typical body and paint pretty cheap. If you want it done right...Its going to cost you big bucks. The guy who had my car went cheap...Cost him about $4500 and they simply masked off the trim instead of removing it. Didn't take the time to smooth the body filler so there are some signs of it in the paint....Its a OK job...will not last....already flaking off.
  3. Wolfman911
    Wolfman911 Member
    52
    Oct 29, 2013
    Simpsonville, SC
    I need mine painted too. The body is pretty straight with no rust, and so far I've been told by most places that they wouldn't touch it for less than $10k, but was also quoted $6k by a reputable shop.
  4. badazz81z28
    17,814
    711
    Alabama
    If its really just a scuff and paint....it can be done pretty cheap. Heck, if my body was that great I would scuff it myself and take it to MACCO.
  5. LJProvost
    LJProvost New Member
    12
    Jan 31, 2014
    Enfield, CT
    I was quoted about $10k for mine as well, from a well established shop. I'm in New England so mine has the typical rusty areas.
  6. RickM
    RickM Veteran Member
    502
    68
    Apr 16, 2004
    Gaithersburg, MD
    I stripped the paint myself and removed all the stuff that wasn't getting paint so my painter only had to do body work and paint.
    Still he had to do a lot of work. Removing doors, fenders, trunk and hood is a lot of effort but is probably necessary to do it right.
    Still in the end it going to cost me around $6500 but I think it is going to turn out nice.
    RickM
    serpent710 likes this.
  7. 78BlueGreen Z28
    78BlueGreen Z28 New Member
    Oct 29, 2017
    Painted my 78 Z28 the original blue green metallic which I suspect because of the metallic will be more expensive than white. Between primer, sealer, base coat and clear I have over $3000 in paint alone using PPG paint. 78 Z28.png
    RickM likes this.
