Parking brake, how much should I try keeping it?
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by SPG, Feb 18, 2021.
  1. SPG
    SPG Bumblebee Builder
    1,032
    354
    Sep 1, 2018
    Sacramento
    Someone suggest a line lock
    not exactly an ebrake since it's still relying on hydraulics but that might be a good solution if I don't want to lose my lever.
    budro6968 likes this.
  2. ruthlessz28
    ruthlessz28 Veteran Member
    134
    24
    May 9, 2009
    carpetersvill, il
    pinion brake. if you have a flange on your pinion its ez . the only time it doesn't work is if you break your axles. only have to worry about one cable and one caliper.
    SPG likes this.
  3. SPG
    1,032
    354
    Sep 1, 2018
    Sacramento
    As much as I like that idea, I don't think that will work with my torque arm
  4. ruthlessz28
    134
    24
    May 9, 2009
    carpetersvill, il
    does your torque arm bolt to the trans or the tunnel? rotor at trans like HD trucks, maybe?
  5. SPG
    1,032
    354
    Sep 1, 2018
    Sacramento
  6. ruthlessz28
    134
    24
    May 9, 2009
    carpetersvill, il
  7. Lowend
    16,331
    1,188
    Mar 25, 1999
    San Jose, CA, USA
    I like E-Brakes. The pin that holds an automatic in park is pretty small. Makes me nervous
  8. Bandit723
    Bandit723 Veteran Member
    3,524
    619
    Oct 1, 2016
    Waupaca WI
    I would like to ask when is the last time one has used a parking brake with a automatic transmission. My answer is i never have.
    scrap--metal likes this.
  9. berg2695
    berg2695 Veteran Member
    489
    142
    Nov 13, 2011
    AUBURN, WA
    Always.
    roadrace2 and SPG like this.
  10. SPG
    1,032
    354
    Sep 1, 2018
    Sacramento
    I'll ask CA if they can integrate the electric or cable driven ebrake in their design
    120-15687 for electronic
    120-12069 for cable driven (preferred)
    If not I'll see if they'll give me the strange ends
    worst case, I just get it directly from strange
