PC crashed... help?
Discussion in 'The BS Topic' started by FreedomPenguin, Nov 27, 2010.
  1. FreedomPenguin
    FreedomPenguin Veteran Member Lifetime Gold Member
    1,393
    161
    Sep 19, 2006
    Dayton, Ohio
    my gf's laptop, it worked fine, we were watching a movie, she loaded a file off the hard drive, and it lagged up, she restarted,
    restarted and its a blue screen, not the one of death. but says like start normal, recovery, diagnostics etc,
    every options restarts back to the screen
    shes sending it to me.
    if i take the hd out can i use it with this and recover her data possibly onto my pc or external?
    it still revved, / the hard drive
    http://www.bestbuy.com/site/Thermal...07083869&skuId=8990443#tabbed-customerreviews
  2. Gary S
    23,601
    1,359
    Yes, from the specs, it looks like you should be able to install the laptop drive into the adapter and recover the files. That is assuming that the drive is still readable.
  3. FreedomPenguin
    1,393
    161
    Sep 19, 2006
    Dayton, Ohio
    because best buy wants 100$ to do it,
    or im thinking buying it for 29$ from amazon and doing myself, + have a handy thing for future
    how hard is it to take out a hard drive? i know how, but is there any soldering required, or just unscrew, unclip, etc nothing special involved. its a hp
  4. COPO
    19,903
    1,852
    HD unplugs from the ribbon cable and power cable. No soldering.
  5. FreedomPenguin
    1,393
    161
    Sep 19, 2006
    Dayton, Ohio
    Thanks alot gonna do it myself :) il learn from it anyway
  6. ATM
    ATM Veteran Member Lifetime Gold Member
    2,268
    Oct 10, 2009
    Morris, Illinois
    Laptop hard drives literally pull out. There is no ribbon cable. Usually you have to remove 1 screw, a small one and it will slide out. I ended up buying a 3 in one drive adapter. You can connect IDE hard drives, and both SATA types to it, I think it was less than $20 from TigerDirect.com. If you were to boot up into SAFE MODE, will it come up? It may be worth a shot and do a System Restore to an earlier date.
  7. FreedomPenguin
    1,393
    161
    Sep 19, 2006
    Dayton, Ohio
    She said safe mode wouldn't work so she mailed to
    me itl be here this week or so il fix it.
  8. angel71rs
    angel71rs Veteran Member
    1,343
    Jul 28, 2002
    El Paso, TX
    Unplug, remove battery, you usually remove a couple of screws that hold HD cover, remove a couple of screws that hold HD itself, out it slides. Some HDs have a plastic ribbon attached to the front of it you can grab to pull it out, some don't, carefully use a small screwdriver to wedge it out using the HD's screw holes.
    Some lappy HDs slide out after removing the cover screws; cover is attached to HD and needs to be transferred to new HD. Watch those little screws, they tend to grow legs and wander off.
    You are supposed to use a static strap, but if I don't have one handy, touch something grounded (metal of faucet if you do it on kitchen table) before you expose it. Holding it from the edges can't hurt. Don't walk on carpet or anything.
    If it has trouble reading, I've had some luck taking the HD, wrapping it inside a plastic bag, then putting in the freezer for an hour or 2. Pull it out of the freezer and plug it in quick, transfer files. This has worked even on a HD that was making nasty clicking noises.
    Last thing, if it's an older laptop, might be an IDE HD. Difference shown here:
    http://www.laptopparts101.com/hard-drive/
  9. FreedomPenguin
    1,393
    161
    Sep 19, 2006
    Dayton, Ohio
    Tyvm it's 2 -3 years old. I will post results next week. Looking forward to saving her laptop
  10. sszz4
    sszz4 Member
    71
    Nov 28, 2004
    Torrington,CT USA
    Another option is to create a Linux bootable USB drive or CD. You can then boot the computer off the Linux and copy over the files to a USB drive or external hard drive.
