pedal mods for hydraulic setup
Discussion in 'High Tech Retrofits' started by purpleflame, Apr 24, 2008.
  1. purpleflame
    purpleflame Veteran Member
    234
    May 7, 2003
    west valley, utah USA
    anyone have to modify the stock gen II pedal assembly to put in a hydraulic clutch, seen that one person did but dont see that it needs to but I may be wrong. just wanna make sure before i put my LT4, t-56 setup in and make sure.
  2. woody80z28
    5,601
    77
    Sep 8, 2004
    walton, ny usa
    I moved the hole a little closer to the pivot point for more leverage, as per advice from Todd. You do not need to though.
  3. nobreaks254
    nobreaks254 Veteran Member
    504
    9
    Jul 14, 2007
    aberdeen, SD
    anyone have any pics of their setup?
  4. Todd80Z28
    11,850
    420
    Jun 11, 2002
    Northern VA
    Small pic, sorry.
    You want the hydraulic rod attached about 1.9-2.0" down from the pivot point, or you'll overtravel the hydraulics. This can cause the clutch fork to touch the edge of the pressure plate. Also, it'll give you a stiffer pedal, and all the engagement will end up right at the top. Most of it will anyway, you don't want to make it worse.
    Todd
  5. woody80z28
    5,601
    77
    Sep 8, 2004
    walton, ny usa
    Here's a pic of mine. I pressed in another piece of steel for strength since the holes overlapped. Then I stuck a 3/8" bolt through.
  6. KJZ28
    KJZ28 Veteran Member Lifetime Gold Member
    3,134
    Sep 26, 2004
    Brewsterico, New Fail
    I hear you can use 3rd gen pedals and graft in the pieces needed.
  7. Mizzouri
    Mizzouri Member
    91
    Mar 30, 2005
    Kansas City, MO
    This thread couldn't have been any more timely for me! I am assuming this would be the same for an LS1/T56 setup right?
  8. angelz28
    angelz28 Veteran Member
    356
    Apr 25, 2006
    Guatemala Central America
    yes:bowtie:
  9. purpleflame
    234
    May 7, 2003
    you could if you enjoy modifying the pedals more than you would need, my research says use the second gen and raise the stud where it needs to be this way your not messing with the brake pedal trying to get it to match up as well.
    either way good luck, now to find out about the stupid speed sensor speedo switch, dang computer ran cars.
  10. KJZ28
    3,134
    Sep 26, 2004
    I was including both the toeboard area and the pedals someone told me it was easy..but I dont know never did it.
