Penetrating oil
Discussion in 'Tips 'n' Tricks Topic' started by falloutboy, Mar 18, 2016.
  1. falloutboy
    falloutboy Veteran Member
    2,283
    15
    May 1, 2003
    Grafenberg, Baden-Württemberg, Germany
    Just found this little article about penetrating oils. Did you ever try the ATF - Aceton one?
    from Engine Builder Tech Solution 2016 Edition
  2. frankz
    frankz Veteran Member
    2,125
    27
    Aug 24, 2009
    Illinois
    That is all I use now
  3. GoldenOne7710
    5,477
    790
    Jun 23, 2004
    Athens, GA
    My cousin's dad, who pretty much gets credit in getting me interested in turning wrenches, used the ATF/Acetone mix for years and years. He always had some mixed up ready to use in one of those metal pump oil guns. That stuff works wonders. The main reason the aerosol canned penetrating oil gets used more (at my house) is the fact that it can be sprayed at greater distances with better precision/accuracy...but it still doesn't penetrate as well as the atf and acetone concoction.
  4. CamarosRus
    CamarosRus Veteran Member
    8,546
    148
    Feb 16, 2000
    Auburn,WA (between Sea & Tac)
    Ive been using KROIL as it was easy to purchase on line......got TWO large cans.
    Works very well as claimed too !!!!!!
  5. Gary S
    23,805
    1,456
    All I use is the acetone/ATF mix. I've had excellent results from it while the commercial brands have failed me.
    I needed to take apart the brake lines on my Camaro a couple of years ago. None of them had ever been apart in almost 45 years. I sprayed the connections with acetone/ATF and let them sit overnight. The next day, the fittings all came apart easily with a flare wrench with no damage to the nuts on the lines. It convinced me.
  6. David79Z28
    1,278
    41
    Oct 22, 2009
    Greenville, TX
    What do you guys put the acetone/ ATF in to spray it?
    Will a standard plastic sprayer work?
  7. perkalator
    perkalator Veteran Member
    1,025
    90
    Aug 27, 2014
    kennewick wa
    This stuff is the best ive ever used.
  8. CamarosRus
    8,546
    148
    Feb 16, 2000
    Tried KROIL to remove the smog line exhaust manifold fittings on my 73 Survivor.
    I got the "Nut" to turn, but twisted the line(s)
  9. Coadster32
    2,210
    326
    Oct 2, 2013
    Milford,CT
    I have Kroil also. I only use it when really needed. It works good...but man does it really stink the place up.
  10. Gary S
    23,805
    1,456
    I picked up a couple of rechargeable spray cans at Menards. Mix the ATF and acetone in the can and put in some compressed air from your air compressor and you have the perfect spray can for the mix.
