Penetrating oil
Discussion in 'Tips 'n' Tricks Topic' started by falloutboy, Mar 18, 2016.
  1. falloutboy
    falloutboy Veteran Member
    2,283
    15
    May 1, 2003
    Grafenberg, Baden-Württemberg, Germany
    awesome, thanks for the replies. I never ever heard of the ATF / Acetone mix.
    The only issue I have, is getting it into a sprayable container, but maybe a little brushing on will do for the first tries if I ever have to get some pesky connections loose again.
    How long do you guys normally have you penetrating "working" before you turn the wrenches?
  2. perkalator
    perkalator Veteran Member
    1,025
    90
    Aug 27, 2014
    kennewick wa
    Yes it does, and it taste horrible.
  3. Camaro75LT
    Camaro75LT Masshole Staff Member Lifetime Gold Member
    6,651
    89
    May 17, 2001
    Boston-ish
    I tried this mix on a caliper bolt not too long ago. Pb blaster and a 5 foot cheater bar ended me up with a broken socket. Atf/acetone sat for a few minutes, poured a little more on then tapped the bolt a few times. I broke the bolt free with a ratchet and a grunt.
  4. Gary S
    23,751
    1,428
    Easy. Just pick up one of these.
    https://www.menards.com/main/tools-...s/reusable-spray-canister/p-1444421230460.htm
    I spray it and let it sit overnight before trying to remove the stuck parts.
  5. Twisted_Metal
    29,027
    2,108
    I have some very rusted shocks to replace in the near future (2000 Jimmy).
    I don't see the rechargeable spray cans listed in-store but Menards still sells them on-line.
    Sounds like the ATF/Acetone mix is definitely worth trying.
    Thanks for the tips!
  6. Gary S
    23,751
    1,428
    My Menards store here in Bismarck shows 5 of them in stock. Check your local stores to see if they might have them too.
  7. RS1979
    4,039
    956
    Jun 18, 2013
    Memphis, TN
    I've always heard that PB blaster was the best; but, after reading this I'll give the ATF/Acetone mix a try.
  8. Fbird
    5,355
    1,355
    Feb 12, 2011
    atlanta, ga
    hey I like that sprayer.... will have to order a couple
  9. balloonpilot
    balloonpilot New Member
    25
    May 9, 2020
    I know this is an older post, but will always be relevant so a little bump is in order.
    I never tried acetone and ATF for rusty bolts but there is a old timer recipe for cleaning/lubing guns called Ed's Red that is acetone, ATF and a oil of some type (cant remember off hand which one) but the recipe can be found anywhere online.
    I have used it for cleaning my guns and it works great for that.
    Will have to try this.
  10. SPG
    SPG Bumblebee Builder
    948
    303
    Sep 1, 2018
    Sacramento
    Here are some interesting videos on penetrating oils
