Pertronix Ignition Question
Discussion in 'Engine Topic' started by Greg73Z28, Jun 16, 2009.
  1. Greg73Z28
    Greg73Z28 Veteran Member Lifetime Gold Member
    210
    Apr 14, 2009
    Joplin, Missouri
    Quick question for you guys. I am running a stock 1973 L-82 motor in my Z28. I have upgraded my distributor from the points to the Pertronix flamethrower setup and have been happy with it for the most part. I am running Delco R44T plugs in the motor. Should I be running different plugs (since these are what the book calls for with the points)? What are you guys running with this setup?
    Thanks
  2. ZS10
    12,166
    Jan 18, 2003
    BC, Canada
    If it runs fine, and they're not fouling they must be ok.
    I have a Pertonix conversion for 6-7 years now. Seems to hold up well, never had a problem with it, and it gets along with my Mallory 685 box nicely.
  3. Erics69
    Erics69 Veteran Member
    157
    Dec 26, 2007
    Winchester KY
    As long as the plug gap is set correctly I think AC plugs are the best bang for the buck plug out there. For a N/A engine anyway.
