peteegger
Windshield/Washer wiring is done!
Got most of the engine wired up today and could start it! Need a battery, jumper the safety neutral and plug the ignition connector in at the column. Going to finish the cooling fans, AC and transmission first though.Good videos, Im currently installing a AAW in my 1970. Had a few detours but getting back on track soon.
Purple Haze! Discovered that a couple of my purple wires for the safety neutral and starter solenoid were incorrectly labeled inside the car at the ignition switch connector and the other purple wire to the inside fuse block. The wiring itself was correct and the engine side purple wire was labeled correctly. Initially caused a little confusion!
