pinion spacer
Discussion in 'Transmission & Driveline Topics' started by LT1 WS6, Jan 12, 2015.
  1. LT1 WS6
    LT1 WS6 Veteran Member
    510
    May 25, 2009
    Sandy Springs, GA
    I've tried doing a search for this without luck. I have found that people don't like Ratech brand though. So, that brings the question to what brand or source can I get a pinion spacer from? I see Randy's R&P has a Yukon brand pinion spacer. Is it any good or is it just a reboxed Ratech piece?
    I don't have the means to crush the normal sleeve is why I'm asking.
    Thanks
  2. big gear head
    big gear head Veteran Member
    6,394
    171
    Jul 30, 2001
    Central City, Ky.
    The Ratech spacers are fine. It's the Ratech kits and differential shims that suck. Many of the spacers are only available from Ratech now that GM and Ford have discontinued most parts for their older rear ends. I think the Yukon spacers are just repackaged Ratech parts.
  3. Protour-Camaro
    Protour-Camaro Veteran Member
    2,111
    Feb 16, 2012
    California
    What do you mean no means to crush a normal sleeve? Just a breaker bar with the socket.
    Edit...and your man card...
    Spacers are ok, just longer to set-up
  4. LT1 WS6
    510
    May 25, 2009
    Sandy Springs, GA
    Thanks guys. I appreciate the feedback
