Please Help!! Speedo gears,
Discussion in 'Troubleshooting & Diagnosis' started by Michaels, Apr 22, 2021.
  1. Michaels
    Michaels Member
    51
    Aug 11, 2019
    1980 Camaro
    hi guys I recently had a tranny shop rebuild my TH350 and install 3:73 gears in the rear end. he said we got the speedo as close as they could. but if I drive 100 km it reads 60km
    thats way off. the calculators for some reason are not working for me.
    i want to change the drive gear and the driven gear.
    my tires are BFG T/A Radial 255/65R15
    my TH350 has the larger gear with the 2" housing
  2. 70-camaro
    70-camaro Veteran Member
    3,271
    1,553
    Mar 25, 2010
    marietta ohio
  3. Michaels
    Michaels Member
    51
    Aug 11, 2019
    thanks but that does not work??
  4. Gary S
    23,812
    1,459
    I don't use those calculators. I do it by simple math. If you drive 100kph and the speedometer reads 60kph, it is slow by a ratio of 1.67 so it needs to have the gear ratio changed by that amount..
    Count the teeth on your existing drive and driven gears and find new gears that increase that ratio by 1.67 and it should be accurate.
  5. DougD
    DougD Veteran Member
    105
    29
    Dec 2, 2014
    Bradenton, FL
    FWIW I found that I needed to swap both gears to get the magic combo. Play around with the counts in combination via any of the calculators.
  6. Twisted_Metal
    29,291
    2,257
    If you have the proper speedometer gears... It could be a speedometer issue.
    Normally they bounce or quit working entirely as I've never seen one that was consistently off unless the wrong gears were installed.
  7. Michaels
    Michaels Member
    51
    Aug 11, 2019
    thank you guys, I found a you tube calculation that says I need a 15 tooth drive gear and a 43 driven gear. waiting on parts, once installed I will report.
  8. 1320feet
    1320feet Veteran Member
    357
    146
    Oct 23, 2019
    Calgary, Alberta.
    Sounds like they set it up for MPH.
  9. Gary S
    23,812
    1,459
    MPH or KPH shouldn't make a difference for Chevy speedometers. They use the same gears and just paint different numbers on the face of the dial.
  10. rocket dawg
    rocket dawg Veteran Member
    426
    50
    May 5, 2015
    Grand Rapids Mi
    A GPS helps while getting it dialed in. I changed gears in a TH350 years ago. It's dead nuts on with the GPS at 60 mph.
