Points to hei conversion
Discussion in '1970 - 1973 Specific' started by c3_dk, Jun 29, 2020.
  1. c3_dk
    c3_dk Veteran Member
    125
    42
    Dec 23, 2015
    Aarhus, Denmark
    Hi,
    I'm thinking about going to HEI (1973 Z28), if I do so, is it then correct, that the + wire from the coil, is not to be used, and the - wire will go to tach on the HEI?
    Thanks,
    John
  2. mallard
    mallard Veteran Member
    756
    178
    Oct 3, 2013
    SK, Canada
    I found this youtube video, but his wiring sure looks crude. :eek:
    If you have the piece of the harness that connects to the distributor and the tach, from whatever car the HEI distributor came from that I'm sure would be helpful.
  3. c3_dk
    125
    42
    Dec 23, 2015
    Aarhus, Denmark
    Thanks for the link.
    Here is a picture.
  4. tom3
    tom3 Veteran Member
    12,619
    618
    Aug 1, 1999
    ohio
    On my 70 the tach wire went to the tach terminal on the HEI dist. I cut the resistor wire at the firewall connector and connected a standard copper wire to the stub of it to power the HEI with full voltage.
  5. budro6968
    budro6968 Veteran Member
    3,691
    673
    Apr 2, 2016
    Jax Florida
  6. c3_dk
    125
    42
    Dec 23, 2015
    Aarhus, Denmark
    Sure I will take 12v from IGN, it was more the coil connection.
    But this it what I need, THANKS :- )
    2ndGenCrazy likes this.
