Polishing gauge lenses
Discussion in 'Interior Restoration' started by secondgenaddict, Jun 3, 2018.
  1. secondgenaddict
    secondgenaddict Veteran Member
    424
    199
    Dec 29, 2012
    Upstate South Carolina
    Scratched lenses BAD
    WASH VERY GOOD
    Get the sanding scratches consistent with 1500 -
    Then water sand with 2000
    Then water sand with 3000 Trizac
    Then fine cut polish by hand
    Finally Swirl remover by hand
    FlaJunkie and 70lt1z28 like this.
  2. tom3
    tom3 Veteran Member
    13,596
    1,117
    Aug 1, 1999
    ohio
    That's a chore, done a couple, but every time you look at the gauges you get some real satisfaction with how good they look.
  3. secondgenaddict
    424
    199
    Dec 29, 2012
    If you think that plastic lenses are a chore...
    TRY POLISHING SOME DOOR GLASS SCRATCHES... .GRRRRRR
    With plastic lenses at least you feel like you make some progress after 2 hours.
    FlaJunkie likes this.
  4. FlaJunkie
    6,447
    253
    Mar 24, 2001
    Rockledge, Florida
    Cool. I wanted to reuse my gauge lenses but they were scratched in one area. I may try your technique.
  5. budro6968
    budro6968 Veteran Member
    3,941
    755
    Apr 2, 2016
    Jax Florida
    I did some a while back. I used my Dewalt buffer on low speed. Wet sanded with the grits mentioned. Mounted the Buffer in a vise and gently laid the lens against the wool pad. This was kind of tricky. I got tired of trying to hand polish. Finished with foam pad and some clear coat cleaner. Duz-all.
  6. secondgenaddict
    424
    199
    Dec 29, 2012
    IF you try to use plastic lens polish after sanding it will take forever... I used actual 3m or Meguires medium, fine, and swirl remover. It only took maybe 10 min per grit... 30 minutes Total to polish the whole thing to optically clear.
    IT took maybe 30 minutes to sand through 3 grits...I used a swirling motion to sand... until the scratches were gone... you don't want to sand just the scratches you may create a distortion.. .or more than is already there :rolleyes:
