Popping out of carb
Discussion in 'Troubleshooting & Diagnosis' started by fbody_mike, Feb 6, 2014.
  1. captaincog
    captaincog New Member
    14
    Sep 5, 2009
    Rialto, Ca
    I had this happen on my 71 many years ago before the new engine ( the numbers matching block is safely stored away) and after chasing timing, carb issues, ignition, wires, fuel, etc. to no avail....it ended up being the camshaft was bad. We stopped counting at 4 flattened cam lobes. I would look there first.
  2. 351maverick
    351maverick full time Ebay seller/hustler/car killer
    3,837
    553
    Aug 11, 2010
    erie, PA
    time to bust out the propane torch
  3. Knuckle Dragger
    16,249
    2,605
    Nov 2, 2002
    Waddell AZ
    You said you backed off the timing, did you reset it before you checked vacuum?
    High idle with a carb is not a vacuum leak unless it's pulling fuel with it. I'm not one to throw parts at stuff but you've checked fuel, compression and some of the ignition. With the weird ass failures I've seen I'd be putting a HEI module in it.
  4. fbody_mike
    fbody_mike Veteran Member
    977
    Mar 24, 2009
    San Gabriel Valley, California
    Well the popping was because of one or two bad plug wires. Like I mentioned above, I had replaced a few plug wires that were bad. Unfortunately the bad wires really fouled out the spark plugs too, so I replaced those all today and all things were running good except for the idle. Gonna get a whole new set of wires next.
    Idle was still really rough, but it runs fine throughout the power band. I also noticed that it would not stall with the idle screw all the way backed out and I could also remove the idle mixture screws completely and it would keep on idling. My father came around at this point and said he had an idea, he took a shop rag and covered the secondary side of the air horn and motor instantly died. So I pulled the AFB to see why the secondary butterflies were hanging open. I found that I slightly tweaked the primary/secondary linkage during the rebuild such that the primary was not forcing the secondaries closed. I tweaked the little arm, the secondaries sealed, and now it idles smooth again.
    So the whole time it was some bad plug wires, and ME, by introducing new variable with a "rebuilt" carb.
