Positive battery cable clip
Discussion in 'Original Drivetrain Topic' started by Allison Winn, Mar 22, 2021.
  1. Allison Winn
    Allison Winn Member
    89
    12
    Jan 10, 2021
    On a 70 Camaro is there supposed to be a battery cable clip somewhere near the idler arm? And does the cable go between the motor mount tower and frame?
  2. Budz
    3,258
    299
    Mar 17, 2002
    Ashburn, Va USA
    The year would help, but there are three clips on a 1970 Camaro and you can see how it routes under the motor mount in the assembly manual. Below are the clips on my '70 Z28.
    1 attaches to the frame near the idler
    1 attaches to a motor mount bolt (mine is attached to the lower bolt, but that's where it was when I bought the car 23 years ago)
    1 is attached to the oil pan.
    The Oil Pan Clip is not in the assembly manual because that clip was attached to the engine during it's assembly prior to the engine being installed in the car.
    jbloake likes this.
  3. Allison Winn
    Allison Winn Member
    89
    12
    Jan 10, 2021
    Thanks for the info and great pics!
  4. 70lt1z28
    4,219
    967
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Does anyone happen to have the oil pan clip available? I’ll take one if the OP finds theirs first.
  5. Allison Winn
    Allison Winn Member
    89
    12
    Jan 10, 2021
    Looks like I'm missing all 3. I see the oil pan clip is available reproduction- anybody have the 2 others I could buy?
  6. Mitch_Z
    Mitch_Z New Member
    22
    Mar 31, 2007
    Detroit, MI
    The Revision Record shows that clip 3990864 was added on 4/1/70 and that clip 3973662 was used prior.
