Mr fleet and muscl car,Waiting on the center section to show up, 3.70 gears going in it. Quick Performance fabricated 9 inch.
Mine are the big Ford new bearing style, it was part of the package.. Perches are std multi leaf for an F Body spring. Received everything in about a month.. They ship in stages..Mr fleet and muscl car,
What bearing ends did you select (and why)? How long to receive from placing order ? Are those wide leaf spring perches? Looking at ordering very similar 9” from same place.
Thanks in advance for any insight.
That makes perfect sense.Subframe "rotisserie" . Bought the basic stand of CL and made the adapter to mount to the front horns. Slide my hoist legs on. So nice to work on it now. Shot epoxy on Tuesday and it made getting to all the nooks and crannies easy. View attachment 135337
Exactly right, so once it is in place the 3 square opening will stick up above ground level a couple inches and have lids that hinge on the pipes that you can see welded in the corners of the openings making it look like flat ground essentially from the air. Birds come in you swing lid open and stand up to shoot.Forgive me for asking, what is a goose pit? I assumes it’s a place to sit while goose hunting.
Great description. That is what I thought it was , neat idea.Exactly right, so once it is in place the 3 square opening will stick up above ground level a couple inches and have lids that hinge on the pipes that you can see welded in the corners of the openings making it look like flat ground essentially from the air. Birds come in you swing lid open and stand up to shoot.
Obviously not my pit but this pic should help.
