Post up your "big wheeled" cars...AKA...17's or larger AND ADD YOUR BACKSPACING INFO!!!!!
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by CarNDrvr, Mar 9, 2009.
  1. Chicagopd50
    Chicagopd50 New Member
    21
    Mar 31, 2018
    thanks for the info.. im gonna go with the us mags rambler 121 black rims...18x8 fronts and 18x9.5 rears. i will go with 285s on the rear and the fronts just like yours
  2. 8pack
    2,706
    175
    Aug 29, 2007
    Western, MA
    Let us know what backspace you go with And Let’s see those pics when you pull the trigger and if you have some hub to fender lip measurements for ride height that would be really helpful! Pics of tire Andy proximity to the rear springs and ebrake cable would be awesome as well.
  3. Chicagopd50
    21
    Mar 31, 2018
    Ok will do..
  4. Rayden2009
    Rayden2009 Veteran Member Gold Member
    168
    29
    May 12, 2016
    Calgary AB
    Here is what my rears look like with 275's, lowered 1.5" @ 5.75" BS. All else is stock. The tightest area is the seat
    belt hump. 285's would be tight, but it think doable. Maybe safer with a 5.7 or 5.65" BS. The fenders are easy to roll if required, and with my set up, not necessary.
    ZackC likes this.
  5. 8pack
    2,706
    175
    Aug 29, 2007
    Western, MA
    Looks great. Doesn’t look like you are running an ebrake. My measurements indicate a possible issue on the drivers side with mine running TA rear discs.
  6. Chicagopd50
    21
    Mar 31, 2018
    Awesome thanks for the info.. from what I remember I had 285s and didn't do any mods. I don't remember the back spacing.
  7. Rayden2009
    168
    29
    May 12, 2016
    Calgary AB
    I have the stock Camaro drums. I plan to use Wilwood big disc in the future. What issue are you referring to? I haven't anticipated any issues swapping to discs, I hope I don't get blindsided...
  8. 8pack
    2,706
    175
    Aug 29, 2007
    Western, MA
    jvle95 likes this.
  9. BonzoHansen
    20,304
    1,561
    Jun 1, 2005
    Scott from Hamilton, NJ
    Guys, please include your backspace/offset info so everybody is helped.
    Rick Figus likes this.
  10. roadrace2
    roadrace2 Veteran Member
    1,745
    102
    Jan 13, 2000
    Earth......?
    Rayden2009 - Thank you for that photo - it really does help alot - as I plan on a 5.75" rear backspace on a 10" rim - was planning on running a 285 tire but, as I can see, I'll be going with a 275 tire. The difference between the total width of a 275 tire and a 285 tire is: .5" difference. So I wont sweat it. Besides, Im sure the 275 tire would be less expensive.....just a thought to everyone studying rims/tire sizes here.
    So, to keep with the rules of this post, this is my plan for wheels and tires:
    Front: 18X9 - 5" BS, 0 offset. - 265/35/18 tire
    Rear: 18X10 - 5.75" BS, +6 offset (per manufactures spec - American Racing) - 275/35/18 tire.
    This set up would be for my 1980 Camaro Z28 - all 4 wheel lips rolled (already)
    Hope this helps others.
