Post up your "big wheeled" cars...AKA...17's or larger AND ADD YOUR BACKSPACING INFO!!!!!
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by CarNDrvr, Mar 9, 2009.
  1. 8pack
    2,706
    175
    Aug 29, 2007
    Western, MA
    Are you stretching the sidewalls out too far on a 10" wheel vs a 9.5" wheel? Is your front end stock, that sounds like a really wide tire for the front. Would like to run something that wide but it seems like everyone runs a 245 up front.....
    looking forward to the Pics!
  2. roadrace2
    roadrace2 Veteran Member
    1,745
    102
    Jan 13, 2000
    Earth......?
    Im currently running a 255/40/17 tire up front - 17X8 - 4.5" BS - no issues. I know Im taking a risk but Im going to take some measurements first when its fully reassembled - and full weight on vehicle
  3. Chevy13
    Chevy13 New Member
    May 27, 2018
    20x10s in the rear and 18x8s in the front
  4. 1973typeLT
    1973typeLT Member
    40
    Jul 22, 2013
    sacramento ca
    Sorry to revive an old post but this mod is useful as hell for the problem I'm having with my sway bar rubbing a little.
  5. Jdubfilms
    Jdubfilms New Member
    Aug 15, 2018
    Love this set up and looking to do the same on my 70. What was the BS/offset for these?
  6. John Wright
    15,032
    336
    Aug 9, 2002
    Rustburg, Va
    Off the shelf Cragar Soft 8 BS:
    17x8" - 4.5" BS
    17x9" - 5" BS
    I'm thinking about getting a 17x9" - 5.5" BS so I can run the same size tire at all four corners, but I have the balance pretty decent right now with what I have on the car.
  7. Jdubfilms
    Aug 15, 2018
    Thanks for the quick reply. I'm going to order them now, just need to pick the right tires. I think the car might have been lowered but guess I'll find out the hard way. Ha.
    Thanks again!
  8. John Wright
    15,032
    336
    Aug 9, 2002
    Rustburg, Va
    I'm running Moog 707# shorter than stock springs in the front and 1 degree of neg camber(top of the tire tilts in), 5.8 degrees of caster, that said the 255/40/17 tires do not rub anywhere except at hard turn to the lock where it rubs the 1.375" swaybar enough to wear off the cadium plating. My car is sitting pretty low, I have to pick up on the fender to get a low profile jack under the engine crossmember.
  9. Zspoiler
    Zspoiler Veteran Member
    3,779
    366
    May 6, 2012
    Federal Way, Washington
  10. Zspoiler
    3,779
    366
    May 6, 2012
    Thats pretty wild .It reminds me of the IMSA cars of the 1970`s.My 1979 Z-28 RS is supercharged also
