Post Your LS & 6L80E Swap PICS
Discussion in 'High Tech Retrofits' started by gmagno, Feb 13, 2012.
  1. mrvedit
    mrvedit Veteran Member
    1,355
    Jun 12, 2009
    Ann Arbor, MI
    I hang around a lot lately on the Ls1tech.com Transmission forum. It is hard to find any kind words there about the 6L80E especially because of its stump-pulling 4.02 1st gear ratio. It seems to be well suited for very heavy vehicles, e.g. SUV, that need that 1st gear to get going. Then 2nd gear is a huge drop to a 2.36 ratio which kills any drag strip performance unless you have a 4000+ rpm stall. I don't personally have any experience with the 6L80E, just summarizing what I read on Ls1tech.
    Note that people on Ls1tech do like the TCI 6-speed auto which is NOT a 6L80E, but instead a custom 4L80E with 6 speeds. Just very pricey.
    Here is a good thread on Ls1tech:
    http://ls1tech.com/forums/automatic-transmission/1380219-6l80e-4th-gen.html
  2. gmagno
    gmagno Veteran Member
    282
    Jan 16, 2010
    Montgomery, TX
    I knew that. This is the closest to completion I can find. Subframe will be back from powdercoater this weekend so I should know soon. Just looking for comparisons.
    http://www.lateral-g.net/forums/showthread.php4?t=25614&page=3
    First of all, I do not resemble a fruit, and the clearance issue is solved by using an STS or modified G8 oil pan. This is a 1st Gen Camaro 6L90 swap.
    http://ls1tech.com/forums/11613532-post116.html
    "Last, and hardly least, is the 6L80/90 which offers the best all around compromise. Second best rating of maintaining RPM levels, highest first gear torque multiplication, gear to gear clutch handoff, an extra stepped forward gear, AND a top gear that multiplies torque 15% greater (1.00 vs 1.15)...and depending on variation...highest torque capacity."
    Apparently it can handle 1000 HP with mods.
    http://ls1tech.com/forums/forced-induction/1284141-lmr-2010-camaro-makes-1000rwhp-through-6l80e.html
  3. gmagno
    282
    Jan 16, 2010
    Montgomery, TX
  4. RICARDO1969
    RICARDO1969 Veteran Member Lifetime Gold Member
    2,086
    Oct 14, 2007
    Waukesha WI
    Flux overload. lol
  5. gmagno
    282
    Jan 16, 2010
    Montgomery, TX
    1970 Camaro L99/6L80E Swap
    Here We GO !!!
  6. LayZ
    LayZ Veteran Member
    1,856
    15
    Jun 9, 1999
    NJ. US
  7. badazz81z28
    17,774
    691
    Alabama
    I feel the OPs pain. Back in 2012 when this post was initiated, there really wasn't too many "direct" bolt-on swap parts. I did my first LS conversion about 2012 and all the swap parts were garage mechanic creations and I had to get my factory crossmember modified (I think BRP was the only one). Now here we are 7 years later...you can find basically anything and made by at least a few different companies. Heck you can even buy stuff for Nissans and Fords now.
