power brakes vs manual brakes
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by arnies81camaro, Mar 26, 2014.
  1. arnies81camaro
    arnies81camaro Member
    59
    Aug 20, 2011
    groveland,ma.
    How much worse are the brakes on a 70 Camaro, power brakes compared to manual brakes? my engine is only making about 7 inches of vacuum, so the power brake booster isn't getting enough vacuum to assist the brakes. anyone have manual brakes on a Camaro? what is needed to change it to manual brakes? thanks!!!
  2. lyrch
    lyrch Member
    65
    Jan 25, 2011
    west monroe la
    I have the same problem. I've been gathering parts to do a hydroboost swap. All I have left to build is the mounting bracket.
  3. K5JMP
    10,216
    9
    Oct 19, 2006
    MORTUORUM VENATOR - Z.R.T.
    I run C5/C6 disc brakes on all 4 corners of my 81-z with a manual master cylinder...
    if you pay close attention to pedal geometry they require very little effort.
    I also love the fact I get a lot more pedal feedback than running power brakes.
  4. The Champ
    The Champ Veteran Member
    4,842
    678
    Sep 14, 2000
    MN
    Our car came from the factory with manual front disc brakes. Car has no problem stopping and the brakes have a nice feel. Originally thought I'd add power brakes - but decided against it.
  5. nobreaks254
    nobreaks254 Veteran Member
    499
    9
    Jul 14, 2007
    aberdeen, SD
    What master are you using?
  6. krabben1
    8,221
    64
    May 16, 2007
    ( . Y . )Delco
    Im using a stock manual system on my 72 BB and it works fine.
  7. arnies81camaro
    59
    Aug 20, 2011
    groveland,ma.
    is the master cylinder the same for power brakes and manual brakes? what do I need to change over to manual brakes?
  8. krabben1
    8,221
    64
    May 16, 2007
    ( . Y . )Delco
    The master has a different size piston/bore.I think its 1" for manual,and an 1 1/8" for power.
  9. sevitz5
    sevitz5 Veteran Member
    1,618
    Feb 27, 2011
    Middle Point, Ohio
    I too have manual brakes with no issues stopping
  10. hhott71
    14,377
    Mar 30, 2001
    Joplin Mo. 64801
    I have manual brakes on both of my 71 Camaros.
    It isn't a bad conversion using factory parts.
    You need a manual MC that has a 1" deep hole in the piston so the pushrod can't fall out.
    You have to use an aftermarket adjustable pushrod.
    You will need to remove the brakelight switch and swap the holes that it was in. You'll move it to the upper hole. The pushrod will go in the bottom hole..
    The holes are a different size, so you will need to do some fabricating.
    The brakes are not hard to push.
    Easily slows the car from 120 mph blasts down the quarter mile.
