Power break booster. Need one a little smaller.
Discussion in 'Tips 'n' Tricks Topic' started by joer, Jan 28, 2017.
  1. joer
    joer Veteran Member
    245
    Sep 25, 2008
    East Brunswick, New Jersey
    Running a big block in a 2nd gen has it's small problems. Just bought a set of Fabricated valve covers. Problem is stock booster is to big. As anyone changed there booster to a smaller one? If so what brand did you use and what size. Looking for a take it out and put it back in without any mod's to my brakes. It's a 79 with a Ls-6. Any help would be Appreciated.
  2. dailycruiser81
    dailycruiser81 Veteran Member
    207
    10
    May 19, 2013
    ft lauderdale
    I used a firebird 4 wheel disc booster cardone. A lot smaller in height
  3. joer
    joer Veteran Member
    245
    Sep 25, 2008
    Would that work with front disc and back drum?
  4. JKC
    JKC Veteran Member
    106
    Jul 12, 2014
    Knoxville Tn
    I ran into same problem and I put a booster and m/c off a 79 trans-am with rear disc brake I got a reman off rock auto for 110.00. p/s nice car. what brand cowl hood is it a 4 inch
  5. hogg
    hogg Veteran Member
    3,194
    31
    Dec 29, 2000
    pegram,tn.,cheatam
    yes,just keep your master cylander and check the lenth of the master cyl. rod
  6. CorkyE
    11,393
    915
    Yes, as long as you use a disc/drum proportioning valve.
  7. joer
    joer Veteran Member
    245
    Sep 25, 2008
    It's a Harwood hood.
  8. JKC
    JKC Veteran Member
    106
    Jul 12, 2014
    Knoxville Tn
    Is it a 4 inch and how was the fit ?
  9. joer
    joer Veteran Member
    245
    Sep 25, 2008
    It's a 4 inch lift off. Good fit. Thanks for the part number on the booster.
