Rustbucket350
Yes. That is exactly why they have a bypass hose. Like I said. I was unaware big blocks did not have this (internally within the block as small blocks do). There is no internal water bypass within the block itself.Isn't that why OE BBC (and late sbc Gen 1e Vortec L31) have a bypass Hose ?
which connects top of water pump to front of intake manifold water Xover.
I am not a big block guy.
However, on a 366, or a 427, the stock intake has something like a 3" hole that you would have to neck down to a much smaller one. Also, since it comes out of the front of the intake, there is very limited room. I put a rubber expansion plug in the front of the intake and blocked the rest. It is true that you will get hot spots in the engine running it without coolant circulating.
