Power Steering fluid change
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by dadgonebroke, Jul 3, 2016.
  1. dadgonebroke
    dadgonebroke Veteran Member
    361
    29
    Jul 1, 2008
    Nature Coast of Florida
    So- I'm changing out all the fluids on the '72. The next chore is to suck out the fluid out of the power steering pump. I remember back then, we used that red Dexron automatic transmission fluid to top off GM cars when they were low. That's all good but what do we use as these fluids have changed over the years to meet new car's needs?
  2. 3SLO5
    3SLO5 Veteran Member Lifetime Gold Member
    3,639
    Jan 7, 2001
    Edison NJ USA
    same old. trans fluid or ps fluid. your choice. nothing has changed in the power steering world. unless you have electric steering.
  3. Gary S
    23,600
    1,359
    The owner's manual for my 70 calls for power steering fluid or ATF. The only improvements that have come along in power steering fluid is the availability of synthetic fluid. ATF is much the same. Synthetics are an improvement over the old stuff. Synthetic ATF is easier to find than synthetic power steering fluid, so I use synthetic ATF.
    Regular power steering fluid turns to sludge when cold. ATF doesn't, so your hoses and fittings last longer with ATF.
  4. warped
    3,212
    Oct 20, 2003
    Sitting in my command bunker waiting for the zombi
  5. Mountaineer
    Mountaineer Veteran Member
    2,092
    8
    Mar 6, 1999
    Where Mountaineers are free
    Suck it out with a turkey baster, fill it with PS fluid. Drive it a while, do it again.
