Power steering gear box recommendations
biggrass
395
GURNEE, IL
Looking for recommendations for a new steering gear box for my 72. I have a leak at the very end of the input shaft where it connects to the rag joint. Thought it was a seal problem but after replacing seals still leaking. Don't need a quick turn setup just something for everyday type driving. Prices are all over the place. Kind of leery of off brands but would consider if others have had good luck with them. Thanks in advance.
biggrass
395
GURNEE, IL
It is leaking at the end of the shaft where the the splines are. I had it removed for a leak on the shaft that attaches to the pitman arm unfortunately it hit the ground upon removal and it started leaking at the point on the input shaft as described after I had it reinstalled
fbody_mike
1,039
San Gabriel Valley, California
I have used Lares products on a few vehicles now and have been very pleased with them. Just a state or two over from you, probably can ship it to you in a day or so. I ordered mine, a 10972 from RockAuto.com and it was dropped shipped from Lares.
I would not hesitate to go with a quick ratio either, that is the 10972. They are not really twitchy when compared to modern steering. 10970 if you want to slower ratio.
Todd Devine
40
Second Redhead. My local suspension shop recommended them and installed on my 70 Camaro. No leaks and steers almost as good as rack and pinion..
Chris Greenley
107
I started out cheep and didn't work for me I started with a cardone box then a lars then a Borgeson thay all had more slop than my ex wife so finally got tired of jacking around and bought a Sweet manufacturing box 12:1 quick ratio and holey cow that box is tighter than a frogs ass almost to good there is zero slop in this box and my car drives like it has rack and pinion now I guess my lesson learned you get what you pay for.
IMO 2 things you shouldn't skimp on breaks and steering
biker
5,275
Borgeson had too much slop? That's surprising.... mine had zero. Maybe you got a defective one?
Same here, mine is perfect. I also had a good one from Cardone, but the Borgeson one definitely turns quicker.
