Power Steering Parts
Discussion in 'Swap Meet Section' started by ALLZS, Dec 6, 2015.
  1. ALLZS
    ALLZS Member
    31
    Nov 11, 2007
    ST LOUIS MO
    All Of The Parts Where Removed From A 70 - 73 Standard Camaros 2 - Nice Clean Non Leaking Power Steering Gear Boxes - 2 P/s Center Links - 2 Steering Column To Gear Box Links - 1 Power Steering Pump With All Brackets Bolts And Pulleys For A S/b If You Need Any Pictures Send Me Your Mail And I Can Get You Some
  2. rust bucket
    rust bucket New Member
    9
    Sep 17, 2010
    prior lake,MN
    How much?
  3. ALLZS
    ALLZS Member
    31
    Nov 11, 2007
    ST LOUIS MO
    Sorry I Missed That Gear Boxes $45.00 Each Center Links $25.00 Each Pump And Brackets $50.00 Plus Shipping
  4. lapedr
    lapedr Veteran Member Gold Member
    667
    23
    Jan 28, 2003
    Pembroke, GA
    Do you have the small 2-piece bracket that holds the power steering hoses to the gearbox?
  5. ALLZS
    ALLZS Member
    31
    Nov 11, 2007
    ST LOUIS MO
    Not Sure What Ones You Are Talking About But I Will Look At The Boxes And See If Anything Is On Them
  6. lapedr
    667
    23
    Jan 28, 2003
    Pembroke, GA
    They look like this:
  7. hogg
    hogg Veteran Member
    3,197
    31
    Dec 29, 2000
    pegram,tn.,cheatam
    Are't the 70 box a different number of turns????
  8. ALLZS
    ALLZS Member
    31
    Nov 11, 2007
    ST LOUIS MO
    The Turn Ratio Is The Same On The 70 &73 Boxes Right At 2 1/2 Turns Lock To Lock Also Both Have The Same Cast #5691676 And The Same Pitmen Arm #3964881 Hope This Helps
  9. giggity
    giggity Veteran Member
    1,624
    411
    Mar 18, 2013
    Pearland, texas
    I just removed these brackets to put on a serpentine belt setup, do you still need them?
