power steering reservoir pump
Discussion in '1974 Specific' started by CamaroNmotion, Mar 20, 2017.
  1. CamaroNmotion
    CamaroNmotion Veteran Member
    387
    41
    Jan 8, 2006
    Buffalo, NY
    Wondering if any owners have a legible decal at this location that's still readable. Would like to reproduce one if I knew what it said. My original has the label in place but is unreadable. Photo attached is not my car...it was handy just to show location. 1974 introduced new wording on the decal, started with CAUTION and had 2 lines of words beneath it, then divided by a line and then BK (which matched up with item on buildsheet). copy_74 Z28 - Copy.jpg
  2. 74BIBELOT
    74BIBELOT Veteran Member
    865
    57
    Jan 19, 2006
    El Paso Tx, Cd Juarez Mx. Las Cruces NM.
    1E6A65BF-454D-4E6A-B34E-2079276F2932.png ALMOST!
    Trying to read the ps pump sticker on this incredible 979 miles z28(Thanks again Clill).
    NOT SURE if correct(60 yrs.)
    tired eyes,,, lol!
    CAUTION
    DO NOT pry ON
    RESERVOIR
    BK
    CamaroNmotion likes this.
  3. Twisted_Metal
    29,027
    2,108
    Heed the warning!
    I tore a hole in the original reservoir in my 78 by prying against it. :(
  4. CamaroNmotion
    387
    41
    Jan 8, 2006
    Buffalo, NY
    That's it! Finally got to see that again after all this time. I was beginning to think that one was lost forever. THANK YOU.
  5. 74BIBELOT
    865
    57
    Jan 19, 2006
    DA45A361-F421-41B2-B3E5-CDC533AD7CC0.png You’re welcome!
    Time ago not sure if for not enough tools or experience sometimes used some “lever” to pry on ps pump to adjust the belts.
    This pic is from a 73 z28 and looks like a “bent” on top.
    (Near the cap)
    Regards
  6. 74BIBELOT
    865
    57
    Jan 19, 2006
  7. twozs
    twozs Veteran Member
    8,817
    171
    Aug 5, 1999
    hopewell jct ny
    You would pry against the other side to get belt tension . I was doing my water pump about a month ago . I had to think twice as my sticker is long gone
  8. CamaroNmotion
    387
    41
    Jan 8, 2006
    Buffalo, NY
    Sure looks like they did just that. Hopefully it doesn't leak. Live and learn.
  9. CamaroNmotion
    387
    41
    Jan 8, 2006
    Buffalo, NY
    Even though the decal had a clear protective layer over it they became unreadable very quickly through normal use. By the way the 1973 decal was a bit different from '74. Basically the same warning though.
