Power Washer Repair
Discussion in 'The BS Topic' started by HurtHorseZ28, Sep 2, 2016.
  1. HurtHorseZ28
    HurtHorseZ28 Veteran Member Lifetime Gold Member
    4,529
    Jul 29, 2000
    Philadelphia Area, PA, USA
    The pump head on my father-in-law's power washer has a hairline crack along the threads on part of the pump that is causing it to leak/spray like crazy. I believe he over torqued the bolt. I have clearer images, but the photo gallery is not cooperating, so hopefully the little ones will work. Aside from spending $150 on a new pump, has anyone repaired something like this? I'm thinking JB Weld, but figured to see if anyone has done it successfully already. The pump head looks to be cast aluminum. Thanks!
  2. Twisted_Metal
    27,555
    1,248
    Before replacing the pump... I would give JB Weld a shot.
    The crack has allowed the bolt hole to become oblong.
    JB Weld the crack... Thread the bolt back in while it's still flexible and put a small C-clamp on it to pull the crack closed around the bolt.
    If it still leaks.... I think you're looking at a new pump.
    Let the JB-Weld harden a full day before you put water pressure to it.
    Good Luck!
  3. Dave Nelson
    Dave Nelson Veteran Member
    4,707
    2,995
    Dec 19, 2003
    Vineland N.J USA
  4. COPO
    18,820
    1,215
    I dought JBW will take the torque unless you helicoil it after. I would aluminum weld it and retap.
  5. 351maverick
    351maverick full time Ebay seller/hustler/car killer
    3,720
    492
    Aug 11, 2010
    erie, PA
    my pump started to leak - I replaced it & WOW what a difference
    that old pump is probably worn out anyway
