Powertrain/ ??? vibration
berg2695
608
You're wrong also
Wow. Someone is quite sure of himself, isn't he? This is the backside of a steel 5-spoke wheel. Please explain how it could be "hub-centric" on a brake drum (or rotor).
Glava
458
Central NY
Well he's wrong. Any stock wheel on a Camaro is HUB Centric. If when you put the wheel on the car, and you have to center it to even go over the brake drum or rotor hub center.. and it fits tightly like our wheels do....guess what.. .that's called Hub Centric. .
Your wheel or wheels are bent or twisted somewhere else, and he couldn't find it or show it to you so that's what he told you
I believe you may be wrong if you look at the rims. They are lug centric not hub centric, so the lugs locate them not the hub.
Glava
458
Central NY
Excellent. How did you paint them?. I have one on my car that's a bit bent I'm afraid
I actually just ordered an on line rattle can kit. Has primer, base coat and clear coat. They came out better than the original paint job from the factory, which had very light paint coverage on the sides of several spokes.
kenny77
3,275
Ft. Lauderdale, FL
Yeah you're right about that....I was wrong. But now I'm really thinking what a bad design our wheels really are. Especially with the 18 YO kid in the tire shop with the air impact gun on those lug holes.
kenny77
3,275
Ft. Lauderdale, FL
So, did you just re-mount your same tires onto the new wheels after you re-painted them? I love the look of those $$$$$$ expensive tires. Damn.
And, how did you prep the surface of the wheels before painting them?
I'm asking because I have one wheel I need to replace and it's going to need to painted my GM #11 white. I'm also kinda wondering if it would be better to just replace all 4 wheels for a good match. I think the wheels are like $1000. for 4 and then re-use your trim rings and caps? Not really cheap but not too terrible
Glava
458
Central NY
That’s what I did just started fresh with 4 new OER rims Jess had them with free shipping, and a small discount offer, so delivered the we’re about $1100.00. They come painted like the 70-74 Z/28, so I just did a light scuff up, wiped them with acetone and did the light primer, then base an then clear. Luckily the tires I switched over are only about 4 years old and have about 800 miles on them
