Price and source for engine.
Discussion in 'High Performance Modifications' started by reinhardt79, Nov 2, 2015.
  1. reinhardt79
    reinhardt79 Veteran Member
    858
    May 12, 2002
    VA BCH, VA
    I'm looking to drop a 500 hp bbc into my 79. The gutless 350 Sbc in it now ain't getting it. I am unsure of where to get one and what a fair price is to expect. I plan to drag race the car and drive it on the street enough to get it to the track. Not looking to break the bank.
  2. 496z28
    496z28 Veteran Member Lifetime Gold Member
    965
    8
    Sep 23, 2007
    Oklahoma City
    BluePrint engines has a nice lineup.
  3. CorkyE
    10,919
    696
    Looking for 500hp? That's easily obtainable with a small block now days, without the weight and size penalties of a pig block. Board member Brandon/Notalent with ATK performance can help you.
  4. loyal guardian
    loyal guardian Veteran Member
    697
    Aug 28, 2013
    helena mt
    aaron at badasscars.com can set you up, only problem is he is expensive. worth it for racing though
  5. Lowend
    15,665
    835
    Mar 25, 1999
    San Jose, CA, USA
  6. badazz81z28
    18,873
    1,004
    Alabama
    What's breaking the bank for you? A good 500hp bbc is going to be pricey. What are the 350 engine specs? If your on a really tight budget and looking to drag, I would suggest a nitrous kit. I bet you could get a nasty 383 or 406 from someone looking to upgrade or go LS
  7. reinhardt79
    858
    May 12, 2002
    VA BCH, VA
    I didn't realize bbc ran the $7-9k range. I was assuming $3-5k range. It looks like a sbc is considerably cheaper. I just want the car to run faster than my 02 camaro which runs a low 13, high 12.
    Where should I look for a quality used engine?
  8. badazz81z28
    18,873
    1,004
    Alabama
    What's the budget? It won't take much to run faster than a stock 4th gen especially if you spray
  9. 77 cruiser
    77 cruiser Veteran Member
    564
    30
    Nov 17, 2006
    Frostbite Falls MN
  10. Lowend
    15,665
    835
    Mar 25, 1999
    San Jose, CA, USA
    Don't buy a used engine. You can make a Small Block run plenty hard enough to do what you are looking to do.
    Let's talk about what's in the car now and what the real budget for this is
