Primering the engine bay
Discussion in 'Body Restoration' started by E Dog, May 19, 2015.
  1. E Dog
    E Dog Veteran Member
    126
    Aug 24, 2014
    Shreveport La
    Want to use epoxy primer on the firewall and inner fenders. Did the factory use enamel or lacquer? The paint store said I might have to put something down UNDER the primer to make it compatible. Help me out guys lol
  2. Iknow2
    Iknow2 Veteran Member
    137
    Aug 6, 2014
    Houston, Texas
    if this helps i just used rattle can enamel, im not finished yet, this was just one can but here is before and after.
    after
  3. zooms80z
    zooms80z Veteran Member
    187
    Aug 17, 2009
    fremont,ne.
    Take everything down to bare metal and shoot it with epoxy....have no idea what they are talking about that something has to be under the primer. Epoxy is a sealer....shoot it then top coat and you'll be fine. My firewall and inner fenders were taken down to bare metal. I shot them in Trans Star epoxy primer. I'll shoot a single stage black on all of it after a scotch pad scuff them when I'm ready.
  4. 76_TypeLT
    6,394
    149
    Jul 26, 2008
    Houston, TX
    you could just leave those areas in epoxy primer and it would be fine.
  5. E Dog
    126
    Aug 24, 2014
    Shreveport La
    Sanding everything down to bare metal, with all those creases and nooks on the radiator support is not something I want to do. I just want to scuff the paint that's already there and lay down epoxy primer on top of it, but I want to make sure it's compatible with the paint that is there from the factory.
  6. badazz81z28
    20,557
    1,381
    Alabama
    What's the end game intent? Just looks?
    I just did mine...just scuff'd it up and spray engine temp enamel over it. No reason to go to such great lengths and spend $$$ on expensive primers and paint unless this is a restoration.
  7. E Dog
    126
    Aug 24, 2014
    Shreveport La
    Well beings that I just spent 80 hours smoothing the firewall I want it to look as nice as possible
  8. zooms80z
    187
    Aug 17, 2009
    fremont,ne.
    My car is apart and I had the rad support, inner fenders, and fenders professionally blasted.....I took a wire wheel to the firewall and cleaned it up as best as I could. I didn't get down to bare metal on the firewall. Then shot it all in epoxy. I didn't have any reaction on the firewall. I supposed you could shoot over a scuff, but I would read and follow the guidelines from manufacturer.
  9. chauncey1970
    chauncey1970 Veteran Member
    208
    Jun 10, 2008
    WEST SUSSEX uk
    They may have been talking about Barcoat to stop reactions of the paint under
  10. kawboy
    kawboy Veteran Member
    542
    Apr 2, 2010
    Indiana
    If they are telling you to put something down before the epoxy, you may want to find another paint store.
