Problem Solved!!!!!
Discussion in 'Competition Camaros' started by 79CamaroZ28, May 2, 2008.
  1. 79CamaroZ28
    79CamaroZ28 Veteran Member
    1,243
    Aug 1, 2001
    tucson, Arizona
    To everyone who was trying to solve my problem of the thing not wanting to rev, i have CURED IT!!!.. Heres what I checked and double checked after talking with everyone on here.
    Wasn't fuel
    wasn't ignition
    wasn't Cam timing
    wasn't Valve adjustments
    wasn't valve springs
    It was the da*n Breathers that i had in it!!!!, Put a pan evac system on it today (dont ever buy jegs brand, ITS JUNK!!!!) after replacing the one way check valves at the auto store i finally got it to pull a vacuum on the crankcase. The thing went wild, No more power loss, no more windage, no more Oil on my valve covers. What im thinking happened was the Crap breathers i had on it (no place on the carb or intake for pvc) Must have been so clogged up that it was building up too much pressure and causing problems in the crankcase. PROBLEM SOLVED!! thanks to all that helped, it now pulls and makes power to 7,000 where it should. Headin to the track tomorrow night to see what i can get out of it now... Nate
  2. ejpii
    ejpii Veteran Member
    246
    Mar 10, 2008
    Northeast
    That's great! Glad to hear it. Something new to add to the problem book.
    EJ.
  3. Mwilson
    Mwilson Veteran Member
    18,569
    132
    Sep 14, 2004
    Raleigh / Holly Springs, NC
    sounds great man, Im gonna hit the track tonite as well
  4. John Wright
    15,229
    408
    Aug 9, 2002
    Rustburg, Va
    cool!...you guys post up some numbers and vids, will ya?
  5. muenk79z28
    muenk79z28 Veteran Member
    462
    Apr 12, 2007
    Franklinville, NJ
    funny how something like a clogged breather makes such a difference! If the motor feels a lot better like you say, you should be tearing up times at the track! good luck.
    I'll be at the track too :) . First time out racing since putting new heads/cam, built tranny and 3800 stall converter.. Should be a fun time getting traction on worn out M/T's. But hey i'll still have fun. If I get a buddy to go with me i'll get a vid of it.
  6. Mwilson
    18,569
    132
    Sep 14, 2004
    cant wait to see it!
  7. rare71
    rare71 Veteran Member
    186
    Dec 12, 2001
    Las Vegas, NV
    This is a bit off topic, but what is the advantage of a pan evac system?
  8. camaronut79
    camaronut79 Veteran Member
    1,149
    Nov 11, 2005
    destin area, fl
    nate how much blow-by are you getting?
  9. Toomanyhobbys
    Toomanyhobbys Veteran Member Lifetime Gold Member
    2,807
    Apr 12, 2005
    Mesa, AZ
    Come on Nate fess up, you stuck one of Marv's motors in LOL
    Glad ya got it fixed, I would have never guessed. Thanks for the heads up.
  10. 79CamaroZ28
    1,243
    Aug 1, 2001
    tucson, Arizona
    Not very much, i can get off the highway and pull a breather and its only a tad little bit.. you will always have some blowby, Im at 4 % leakdown and like i said, it has just a tad.
