80Camaroman
My '80 Berlinetta Camaro has been experiencing some transmission problems lately. It has a modified 355 engine with a TH-350 Automatic transmission. Every once in awhile it slips out of Drive then re-engages when the shifter is in the Drive position. This occurs no matter if my car is in motion or stopped at a traffic light. I did check to make sure the shifter was engaged properly into the drive position and it still happens. It seems most noticable when my car accelerates or attempts to accelerate initially then it pops into gear. I drove the car today and it did this again. I am almost afraid to drive it because I don't want to tear up my tranny and get stuck somewhere. I checked the transmission fluid level and the fluid itself today and all appears normal. To check and see if the shifter cable was out of adjustment, I attempted to start the engine in all gears except Park and Neutral and the engine would not start in the other shifter settings. Anyone have any ideas what would cause this? The old Haynes manual says to take the car to a qualified mechanic if all the above checks out okay. I don't know much about these TH-350 automatic transmissions. Any help would be greatly appreciated. Thanks in advance.
Jim
'80 Berlinetta
Jim
'80 Berlinetta
