ReorangeCamaro
camarolife78 said:I would get a new set of hinges if the pin wore the hole out that bad....Its what I did, long term will probably have better results
I did. Well kind of. I got a new set of old hinges from the junk yard. You see ive never mentioned that this car was in a wreck when the previous owner was t-boned right where the door meets the fender. Anyway...the old hinges were a bit out of alignment when compared to my newsed hinges. The top hinge, bottom holes of the newsed aren't nearly as bad. Actually look pretty good and the new bushings are pretty snug. Same on the passenger side. We'll see when I'm done. Worst case scenario I'll buy the upper hinges and restore the bottoms. But I'm confident it can be done!
http://www.classicindustries.com/product/1980/camaro/parts/1706371.html
I think hinges were a tid bit cheaper at National Parts Depot.
https://www.npdlink.com/store/products/hinge_assy_door_upper-108562-7.html
