Project "I must be Insane"
Discussion in 'Project Progress' started by 76 for 26, Sep 1, 2017.
  1. 76 for 26
    76 for 26 Member
    56
    22
    Dec 29, 2015
    NC
    Forgot to attach a copy pics..nothing stunning though
    SSgtFig and roadrace2 like this.
  2. 76 for 26
    76 for 26 Member
    56
    22
    Dec 29, 2015
    NC
    To make a little more sense, I was going to seam seal the seam just to the right of the tape and put a thick line up top where it connects to the a-pillar attachment point. Is this right and how do I handle the heat ( bead would run right between the spot welds represented by the blue tape dots). Should I use different seam sealer versus the 2k to give more time to weld the panel in and if so...what type and brand. Epoxy is spi. One last question, how is everyone sealing the cowl along the area the windshield sits just above. Sealing after installed? This are also had sealer sandwiched between the cowl and lower panel, but no idea how to handle as would think it would light up as soon is I started welding.
