Project Rusty - 1975 Camaro
Discussion in 'Project Progress' started by Clay K, Nov 15, 2018.
  1. dave@ztech
    [email protected] Veteran Member Lifetime Gold Member
    4,633
    1,058
    Mar 27, 2016
    NY
    Nice detailed work, nice skills , wish I knew how to weld.
  2. Clay K
    Clay K Member
    39
    20
    Nov 15, 2018
    Madison, Alabama
    I was having some surface rust issues where I had stripped the car. So this weekend I sprayed the bare metal with Summit Racing epoxy primer. IMG_1219.jpg IMG_1220.jpg IMG_1221.jpg IMG_1222.jpg
    hubedobeedo and roadrace2 like this.
  3. Clay K
    Clay K Member
    39
    20
    Nov 15, 2018
    Madison, Alabama
    Here is a shot before the primer.
    hubedobeedo likes this.
  4. roadrace2
    roadrace2 Veteran Member
    1,787
    117
    Jan 13, 2000
    Earth......?
    Clean work! Love it.
  5. scrap--metal
    scrap--metal Veteran Member
    100
    15
    Jan 8, 2007
    This door jam repair looks amazing. Very nice work!
    My '79 has a similar issue. The inner support is cracked near the jam nut. That's allowed the door to move and that movement cracked the exterior metal as a result. It's been that way for years, and I really want to fix it. Does anyone know if the inner support looks the same on a '79?
    I was thinking that it was a smaller piece welded in behind the door jam... I'd feel a lot more comfortable tackling the project if the inner support on my '79 looks similar to Clay's pictures, now that I've seen them.
  6. Clay K
    Clay K Member
    39
    20
    Nov 15, 2018
    Madison, Alabama
    Thanks Scrap--Metal. I'm not sure what the '79 structure looks like. Here is a shot looking out. You should be able to take the vent off and look inside with a mirror and see if it looks the same.
  7. Clay K
    Clay K Member
    39
    20
    Nov 15, 2018
    Madison, Alabama
    I've been looking into what it will take to replace the trunk pan. So, everything that I have seen shows the taillight panel being off for the replacement. Can the taillight panel be put into place without removing the tail pan? If so, do you put it in from the bottom?
  8. Clay K
    Clay K Member
    39
    20
    Nov 15, 2018
    Madison, Alabama
    It's been a while since I've posted anything. A lot has happened though there isn't a lot to show. I found a parts car that I could get the tail light finish panel along with some other parts from it. I spent quite a bit of time tearing it apart and figuring out what I could use.
    I started fitting my floor pans. I liked the way it is fitting until I looked towards the back of the panel where it ties into the torque box. It looks like the transition to the rear seat pan is 1/2 inch too far forward. I guess I'll be cutting the pan and splicing in an extension to get it in the right place.
    IMG_20190921_201031.jpg IMG_20190921_201051.jpg IMG_20190921_201144.jpg IMG_20190921_201338.jpg
    Also, I finally got the engine I planned to used from my dad's house. I was hoping that I could just freshen it up and have an inexpensive motor to get me going. Unfortunately, when I pulled the heads off I saw that water had gotten into 3 of the cylinders and rusted them. So, I'll need to tear it the rest of the way down and see if the cylinders can be salvaged. So much for a cheap motor...
    [email protected] likes this.
  9. Clay K
    Clay K Member
    39
    20
    Nov 15, 2018
    Madison, Alabama
    After much contemplation, I cut the floor pan and fit it to the torque box area. Now I need to cut out my fillers and weld it up.
  10. ZerroHalfcup
    ZerroHalfcup Member
    42
    19
    Apr 2, 2019
    Memphis, TN
    The guy who "fixed" your floor must have been the same guy who did mine. I'm looking forward to seeing how you replace your left inner rocker. I regret starting to patch mine the way I am, I think it would have been much easier to just replace the whole panel at this point. I have some pictures of my floors and rocker in my thread here, feel free to critique.
    http://nastyz28.com/threads/77-type-lt-budget-build.324250/
