Proportioning Valve and Exhaust Y-Pipe
Discussion in '1977 Z28' started by Zcarman, Jan 1, 2016.
  1. Zcarman
    Zcarman New Member
    8
    Mar 30, 2008
    Street, Maryland
    Looking for original Bendix 0411, 007 brake proportioning valve and y-pipe between catalytic converter and mufflers. Threads stripped on original proportioning valve when I was tightening brake line. I have not been able to locate y-pipe. Purchased new mufflers and tailpipes from Walker. They do not repro y-pipe. Want to maintain original looks. Any recommendations? If not available I will prefab y-pipe and use modern proportioning valve.
  2. Plater Tom
    Plater Tom Veteran Member
    1,465
    58
    Feb 2, 2003
    Mt Pleasant, Pa. USA
    Hello, Have you found a Y-Pipe yet? Tom
  3. severum17
    severum17 New Member
    29
    Sep 5, 2001
    South of Dallas TX
    Dont worry about it. (y pipe) Leave it off and put true duals on it. I am an original owner and my y pipe has been in the basement for about 37 years now. No, I dont want to sell it but there is no need for it. JMHO
  4. Mark80Z28
    Mark80Z28 Veteran Member
    1,459
    Aug 16, 2006
    Ohio
    Last I knew, there was a repro available for the Y pipe. Have you tried NPD or Classic Industries? The one on my car was missing when I bought it years ago and I was able to order a replacement at the local parts store. But again, that was a long time ago.
  5. falloutboy
    falloutboy Veteran Member
    2,283
    15
    May 1, 2003
    Grafenberg, Baden-Württemberg, Germany
    Y-pipe should be available as a Walker Exhaust part, provided the rest of the exhaust system is OE still.
    For the Prop Valve, IIRC there are some CPP or other companies prob valves that work for the Brake system, but do not look correct in terms of restoration.
  6. Zcarman
    Zcarman New Member
    8
    Mar 30, 2008
    Street, Maryland
    Thanks for everyone's feedback. Ended up having Y pipe and 4 bolt catalytic converter flange made. Did purchase after market Prop valve.
  7. falloutboy
    2,283
    15
    May 1, 2003
    pictures or it didn't happen :D
