Pulley alignment
Discussion in 'Engine Topic' started by spav350, Jul 1, 2014.
  1. spav350
    spav350 Veteran Member Lifetime Gold Member
    601
    Apr 8, 2009
    Corpus Christi, Tx
    I'm looking for some help on the pulley alignment regarding the power steering pump. I am finally installing A/C and want to know if the rear groove on the double groove p/s pulley is supposed to line up with the rearmost groove of the crank pulley. My crank pulley has one large groove on the front side and the two behind it are the same size. My car was an original A/C car but when I bought it, it didn't even have an engine, so I'm flying blind here.
  2. Damon
    Damon Veteran Member
    12,939
    24
    Nov 16, 2000
    Philly area
    Yeah. Rear-most groove on the PS pump goes to the rear-most groove on the crank.
  3. spav350
    601
    Apr 8, 2009
    Corpus Christi, Tx
    Ok...I had a used 2 groove p/s pulley and a used 3 groove crank pulley a friend gave me. I pressed on the p/s pulley and bolted up the crank, but the p/s pulley only lines up with the front two grooves. It won't press on anymore. Any idea why?
  4. spav350
    601
    Apr 8, 2009
    Corpus Christi, Tx
    Can anyone post a photo of their pulley setup with belt routing with the A/C comp on the driver side? And does anyone know if the aftermarket Saginaw pulley that is available from summit would work?
  5. Damon
    12,939
    24
    Nov 16, 2000
    Philly area
    I think it would be more helpful if you posted up a pic of what you've got. Lining up with the front two grooves on the crank pulley doesn't sound right at all. Front groove is ALWAYS for the Alt & WP on a v-belt SBC car. I've seen no exception to that rule.
  6. spav350
    601
    Apr 8, 2009
    Corpus Christi, Tx
    I will, once I get a new p/s pump pulley. I bent the hub on mine trying to press it on further. :/
  7. Damon
    12,939
    24
    Nov 16, 2000
    Philly area
    If it's a later model pump (no retaining nut on the front) the pulley should press on until it's flush with the front of the pump's input snout.
  8. spav350
    601
    Apr 8, 2009
    Corpus Christi, Tx
    Found out i had the wrong double groove p/s pulley. Back in business.
  9. Damon
    12,939
    24
    Nov 16, 2000
    Philly area
    Cool.
