Pypes crossflow system questions
Discussion in 'High Performance Modifications' started by LT1 WS6, Aug 21, 2014.
  1. LT1 WS6
    LT1 WS6 Veteran Member
    510
    May 25, 2009
    Sandy Springs, GA
    I did some searching but wasn't able to find what I'm looking for. I'm hoping some of you with the system can help. I'm really interested in the crossflow system with the x-pipe for ground clearance reasons. In most of the pictures, it appears that the system does indeed tuck up very well to the car. I can't see if any of it hangs below the subframe or floor in all the pictures I've seen though. Does any one have good pictures that show how much if any the systems hangs down?
    Also, I'm wanting to just simply dump the tail pipes out the sides behind the rear wheels. Similar to how an A-body would exit. Can I do that with this system? I imagine I'll have to modify the system a bit since these cars didn't exit the exhaust originally like I'm wanting. From the pictures I have seen, it appears the tail pipes don't come down the same distance behind the wheels so one would be further back that the other. Is it just bad angles I'm seeing in the pictures? Do the tail pipes come down in the same spot behind the rear wheels?
    Lastly, has anyone had issues with running wider tires with this system? I have 18x9.5 rims with 275/40 rear tires on the rear.
    Thanks
  2. krabben1
    8,244
    72
    May 16, 2007
    ( . Y . )Delco
    The pipe will tuck up as far as you want,its the headers that will govern you a little.I used shortys and another app downpipes for the Camaro,and another company's 45* pieces for my chevelle.
    Yes you can dump them behind the rear wheel.They end right there,and with the kits I received,two 12" pieces that can be used.
    I have the x pipe with the transverse muffler on the Camaro.
  3. LT1 WS6
    510
    May 25, 2009
    Sandy Springs, GA
    Thanks for the reply and pictures. I figured the tip exit points was just the weird angles the pictures were taken at but I wanted to make sure. I also intend to make my own tri-y headers to ensure I have great ground clearance. I haven't found anyone that makes tri-ys that will fit my LT1. It also doesn't help that I have a WS6 car. That's why I plan to make my own.
    Thanks again.
  4. Rick@Metco
    [email protected] Member
    47
    Oct 8, 2013
    Anderson, SC
    About to install that same kit on our car with long-tubes...How does it sound?
  5. krabben1
    8,244
    72
    May 16, 2007
    ( . Y . )Delco
    Me?
    Quiet till you get on it.
  6. mickstan
    mickstan Veteran Member
    927
    Jun 11, 2012
    E'ville, IL
    I've got the same system on my 355 with hedmann headers. Sound great! I've been told by several people, (mustang owners too!), that my car has the sweetest combination of rumble and thump. I really like the way it sounds. Fairly quiet but thumping at idle and cruise, but really screams when you get into the 4-barrels. And no "drone" at highway speeds, just a nice purr. I've got a 500 watt alpine stereo system that will blow you out of the car, and I hardly ever even listen to it. The engine makes sweeter music.
  7. 79Berlinetta22
    79Berlinetta22 Member
    88
    Jan 20, 2011
    Houston,Texas
    Dynomax Ultea-Flo X Muffler
    Dynomax #289-17553
    2.5" duel inlet/dual outlet
    Transverse mount in stock location
    Great ground clearance
    Quite idle
    1300 cfm
    pypes stainless hockey exhaust tips, "look original"
    Shorty headers
    Rod
