Quadrajunk
Discussion in 'Engine Topic' started by brooksman9, May 5, 2021.
  1. 1980RS
    1980RS Veteran Member
    5,228
    1,659
    Jun 17, 2006
    MN
    A good tuned Q-jet will blow a Edelbroke carb away. There was a reason GM went away from the AFB carb. A 1406 is a junk tune out of the box, lean as all hell.
    Dave Nelson likes this.
  2. brooksman9
    brooksman9 Veteran Member
    6,294
    303
    Jun 10, 2007
    Olive Branch, MS
    Called Cliffs. Had to leave a message. I'll try again on Monday.
  3. 77 cruiser
    77 cruiser Veteran Member
    587
    36
    Nov 17, 2006
    Frostbite Falls MN
  4. COPO
    20,782
    2,403
    The best Quad GM installed was on the 1968 Chevelle.
  5. brooksman9
    6,294
    303
    Jun 10, 2007
    Olive Branch, MS
    Talked to Cliff finally. He does like to talk. lol. Really nice guy. He did tell me he doesn't work on anything from National Carburetors but is more than willing to help me with me working on it. From the model # I gave him he did say it was a better quality base to start from. Seems to be a 850 from a early 80's model truck. I am going to get his book and I guess finally learn about carburetors myself (other than mixture screws and idle setting). Since it does run good just rich (although he said it could be really lean) maybe I don't have too far to go. I'm sure I will have questions here as well.
  6. brooksman9
    6,294
    303
    Jun 10, 2007
    Olive Branch, MS
    Got my book. Time to study.
    BillyDean7173 likes this.
  7. biker
    biker Veteran Member
    3,453
    1,541
    Dec 7, 2014
    Nice! You will like it.
  8. Happy_Dan
    Happy_Dan Veteran Member
    1,132
    300
    Sep 13, 2013
    New Boston, NH
    I need that book
  9. berg2695
    berg2695 Veteran Member
    494
    145
    Nov 13, 2011
    AUBURN, WA
    I was a QJet fan in my younger days. One modification I always wanted to do but never got around to is bore the primary throttle bores for bigger throttle plates. This is a killer mod because the flow capacity of the primaries is increased significantly without enlarging the venturi size. The much more efficient primary side of the carb then is sufficient for most driving short of full throttle, high rpm. Better mileage, more power. It's almost like a free lunch. As I recall, Thermoquad throttle plates were used.
  10. brooksman9
    6,294
    303
    Jun 10, 2007
    Olive Branch, MS
    Hopefully I don't have far to go. Car actually runs really good it just stinks to high heaven no matter what I do. Should be a good learning experience though.
