Questions About Subframe Connectors
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by evilWS6, Jul 8, 2015.
  1. evilWS6
    evilWS6 Veteran Member
    338
    9
    Jan 22, 2013
    ny
    Hey everyone! How we all doing?
    Well it's about time for connectors, i think. I got my front suspension all refreshed, bilsteins all around and solid body bushings. I was just looking around and I really like how Custom Works connectors are looking.
    Questions:
    1. Did you guys weld them in fully or bolt the fronts into the subframe so the subframe could still be removed? I plan on keeping this car forever, and I'm sure sometime in the future I would like to remove the body from the subframe.
    2. Is any rigidity sacrificed by bolting the fronts in rather than welding?
    3. Should I do anything prior to putting them in? The brake and fuel lines are fine, and the car is already undercoated. Not sure if anything will be blocked or hard to get to.
    4. How much more will I love the car once they're in? :D
    Thanks everyone!
  2. JONESYFXR
    JONESYFXR Veteran Member
    2,177
    Oct 10, 2009
    BUFFALO, NY
    Well, you have all your bases covered for sure. You can bolt them in with no issues, but weldeing is really the way to fly. Some guys do both. I'd say do what you're comfortable with. A weld can always be cut and ground to remove a part too.
    I'd recommend buying the Alston frame ties. They are VERY low profile and fit well too.
  3. JONESYFXR
    2,177
    Oct 10, 2009
    BUFFALO, NY
    double post
  4. harbone66
    3,498
    288
    Feb 15, 2011
    Central Illinois
    I used Heidts bolt ons when I bought a set for my 73
    Great fit and great finish
  5. evilWS6
    338
    9
    Jan 22, 2013
    ny
    How annoying is it to cut out a weld? Something that would take a few minutes each weld or would it be something future me would hate myself for doing? lol. At this point I'm 23 years old and don't have much of a work space, but I could guarantee that in the future the body will come off this car at some point.
    I've never heard of Alston or Heidts.
    Also... How are those wooden stands made? They look pretty sweet.
  6. earnhardtgm3
    earnhardtgm3 Veteran Member
    4,326
    52
    Dec 18, 2007
    Camaro Country,GA
    I have the Custom Works subframe connectors and mine are bolted in with solid body bushing mounts. Here are mine while installing pypes exhaust.
  7. evilWS6
    338
    9
    Jan 22, 2013
    ny
    Thanks for the pics! How much did it improve the car? I've read about the rear frame rails being too thin to be worth bolting into. How long have you had them in, and do you drive the car hard? I drive mine multiple times a week, and along with it getting beat up by suburban NY roads, I throw the car around a lot as well.
  8. Z-WIZZ
    Z-WIZZ Veteran Member
    1,297
    Mar 18, 2004
    FLA
    IMO unless its a track only car, id say bolted is fine
  9. bigdav160
    bigdav160 Veteran Member
    592
    Jan 11, 2006
    Klein Texas
    I'm using Global west. Welded in the rear and bolted in the front.
  10. 75Camaro4x4
    75Camaro4x4 Veteran Member Lifetime Gold Member
    345
    Aug 5, 2013
    Wilson, NC
