bitchin'71SS
Thanks fellas, and welcome to nastyZ Loco.
130 amps should be enough to weld the cage. You welding up the sub frame. The welds looked a little cold, but what setting did you have it on. the cage and pipe is 1/8", so your machine should be enough. If you can, get some pipe from the cage and try to weld it. Is it 110v or 220v? My 2 cents.badboyrcg70 said:Progress is coming along nicely.
How do you like that welder.
Eastwood used to sell a Clarkeweld brand which is what I have, but its
only a 130. So I will need to upgrade to do the rollcage.
The rotisiree seems to work good. I may need to get one.
What are you using for a bender?
