Radiator question
Discussion in 'Troubleshooting & Diagnosis' started by bazookatooths, Oct 25, 2019.
  1. bazookatooths
    bazookatooths Member
    37
    Apr 25, 2018
    OKC OK
  2. jeff swisher
    jeff swisher Veteran Member
    1,863
    635
    Apr 26, 2018
    Yukon Oklahoma
    Stepped down upper outlet .I have never seen that on a factory old school radiator.
    Not saying it did not happen.
  3. Green hornet
    Green hornet Veteran Member
    2,027
    477
    Oct 11, 2015
    North Bay, CA
    What is the core length? I believe stock core length is 20 inches non a/c and 26 inches a/c and hi performance models.
  4. bazookatooths
    37
    Apr 25, 2018
    OKC OK
    Comes in at 26" cool thank you
    Are you talking about the upper right? It was plugged, but I'm trying to make a homemade fitting for a steam line. I have no idea what the original usage for it.
  5. jeff swisher
    1,863
    635
    Apr 26, 2018
    Yukon Oklahoma
    Upper left the radiator hose looks stepped down and long.. that is what newer aftermarket radiators have that I have seen..Factory original I have not seen that.
    Not talking factory replacement..I am talking Original.
    That upper right area you plugged off I have seen and if it has a hole through it into the antifreeze area it is actually used for going to the heater core.
    It would have a heater hose fitting threaded there.
    Most all of my Oldsmobiles had it.
    My first junker had a stick pounded into the hole to plug it off and no antifreeze ever leaked from it.
    Like a wood whiskey barrel.. it will seal up tight with liquid in it.
    Let it dry out and it will shrink.
