Radiator with different hose sizes? HELP
Discussion in 'Troubleshooting & Diagnosis' started by ratpatrol71z28, Mar 31, 2016.
  1. ratpatrol71z28
    ratpatrol71z28 Veteran Member
    1,577
    Mar 29, 2012
    Mantweeka, California
    Hey guys, I'm working on a 1978 with a sbc 350 with A/C. It originally had a 3 row in it.... after testing it I found a few leaks so it is no good. I have two spare radiators both identical to the other radiator that was in the 78, the only problem is the upper inlet is smaller in diameter than the other radiator. So basically the upper hose is too lose and won't fit in tightly.
    Why are they different than each other? If I can adapt it to work, will I have any problems or should it work like any other normal radiator?
