Ram Air Cowl Hood
Discussion in 'Body Restoration' started by Zulu28, Apr 22, 2017.
  1. Zulu28
    Zulu28 Veteran Member
    298
    26
    Dec 19, 2013
    Vancouver, BC
    For those interested in cowl and ram air hoods, this is the hood that Eric of MPD1 Motorsports is building for me as of this writing, I've been looking for something different for a long time and then I came across the Passionately Pink Camaro that was built and donated for cancer research, it was an interesting project that several companies donated their time and products to see this build through, Eric of MPD1 was one company that got on board and donated his time, I waited for a long time to see if MPD1 was going to produce that same hood and then I decided to call MPD1 and Eric explained that the hood on PP Camaro was the only one built, the hood that Eric is building for me will involve several changes, mostly to the underside, the plan is to make this hood functional which will be up to me to figure out when I get the hood on the car and see how everything will line up with the Ls intake.
    http://www.mpd1.com/gallery/customs_eric/Pink_Camaro/Zforce_pink/cust_gall_zforce_pink16.html
    Here's a couple of pics of the underside starting to take shape!
  2. rgfast
    rgfast New Member
    24
    Aug 22, 2013
    Fleming GA
    I like it, Reminds me of the 67 corvette design hood
  3. Zulu28
    298
    26
    Dec 19, 2013
    Vancouver, BC
    Yes similar, there were other scoops as well in the seventies.
  4. Zstar
    Zstar Veteran Member
    2,346
    760
    Mar 23, 2014
    Ocala, Florida
    That is the hood we have all been waiting for. If I had not already bought a Harwood Pro touring hood
    I would buy one. That hood will sell like hotcakes!
  5. Zspoiler
    Zspoiler Veteran Member
    3,921
    412
    May 6, 2012
    Federal Way, Washington
    There were similar hood scoops on the IMSA /SCCA race cars back in the 70`s You will probably add some bracing similar to a GlasTek hood to make it a bolt on hood.
  6. ULTM8Z
    ULTM8Z Veteran Member
    9,884
    790
    May 19, 2000
    Los Angeles
    Agreed! I'd probably buy one myself too!
  7. Zulu28
    298
    26
    Dec 19, 2013
    Vancouver, BC
    Here's another pic of the PP Camaro in a different paint scheme, I sure wouldn't be to terribly upset if I found this in my driveway!!!
    Zstar likes this.
  8. Zulu28
    298
    26
    Dec 19, 2013
    Vancouver, BC
    Not quite sure I understand but I'll give it a shot, the hood will be fully finished on the underside with framework and will be a bolt on, it will function as OEM, here's a pic of the framework, hope that helps.
  9. Zspoiler
    3,921
    412
    May 6, 2012
    Are you going offer "light" and or some sort of strut system. Then maybe a basic cold air box for your customers? It might help you sell more.
  10. Zulu28
    298
    26
    Dec 19, 2013
    Vancouver, BC
    Good question, I'll either modify my original hinges or go with an aftermarket design.
