Rear axle Chevelle vs Camaro
Discussion in 'Transmission & Driveline Topics' started by Silkesvarten, Feb 5, 2008.
  1. Silkesvarten
    Silkesvarten Veteran Member
    405
    Jul 15, 2005
    Norway
    I'm having a rear axle from a 75-76 Chevelle in the backyard. Measured the with (flange to flange) , seems to be the same as the Camaro. Or am i wrong ? This axle have "real" bearings not going direcly on the shafts. Would't it be better welding brackets to this axle and using this ?
    Olav
  2. blades67
    blades67 Veteran Member Lifetime Gold Member
    1,542
    Oct 22, 2005
    Chandler, Arizona, USA
    The Chevelle uses a trianulated four link suspension and the Camaro uses leaf spring suspension. The Chevelle rear could be used on the Camaro if you cut the "ears" off the diff housing and weld on some spring pads.
  3. Silkesvarten
    405
    Jul 15, 2005
    Norway
    rear axle
    I know i have to cut the ears off.... and add brackets for the springs :p :p
    Olav
  4. Gary S
    23,355
    1,248
    Measure really carefully before you start. I don't have the measurements for that axle, but I know that 73-77 Chevelle and Monte Carlo used the same width axle as 77-90 Caprice and Impala.
    70-81 Camaro used the same width axle as 68-72 Chevelle.
  5. 74BIBELOT
    74BIBELOT Veteran Member
    865
    56
    Jan 19, 2006
    El Paso Tx, Cd Juarez Mx. Las Cruces NM.
    Here's this information, hope it helps.
    F Body=58.5 in. leaf springs(Camaro&Firebird)
    A & G Body 60.0 in. coil springs(Chevelle&MC)
