Rear Bumper Install 71
Discussion in 'Body Restoration' started by Kris g, Jun 14, 2014.
  1. Kris g
    Kris g Veteran Member
    115
    Jul 19, 2009
    Do you need to install brackets on the bumper first or on car? Can you leave them loose and once in place can the chrome bolts be tightened?
  2. krabben1
    8,245
    74
    May 16, 2007
    ( . Y . )Delco
    Install brackets on bumper tight first.
    When putting it on the car(painted)I put either socks over the ends of the bumper,or clean rags with a rubberband.
    I also use 4" 3/8" bolts(shank wrapped in duct tape) to hang the bumper so I can put it on my self without damaging the car.
  3. Kris g
    115
    Jul 19, 2009
    Awesome thanks. I guess there is enought play in the through holes into the trunk to make up for any play in the brackets.
  4. roeville
    roeville Veteran Member
    1,276
    116
    Oct 9, 2000
    SF East Bay CA
    There absolutely is.
  5. Kris g
    115
    Jul 19, 2009
    OK Guys,
    I got the bumper on alright, no scratches :)
    The passenger side sticks out about a quarter to half inch further than the drivers side. Drivers side is perfect.
    I've narrowed it down to the right side bracket with the 2 bolts. It is sitting further from the rear panel than the one on the other side.
    I'm going to try loosening the carriage bolts and manipulating it. If that doesn't work I wonder if I may have one 73 Bracket?
  6. 1971CamaroGuy
    3,831
    200
    Oct 31, 2004
    Is this a freshly painted car? Did you test fit the bumpers before paint?
    The reason I ask, if were me I would use a hammer and a couple of well placed blows in the area where the passenger side goes into....to make sure the metal isn't buckled, if so this would level it out or at least push it in a bit.
    But kinda hard to do when the car has paint on it
  7. Kris g
    115
    Jul 19, 2009
    Thanks Dennis,
    It is painted. I really think it is a Bracket/Bumper issue as it seems more about how far the bumper sits away from the tail when heading toward the passenger side.
    I'm going to remove the carriage bolts on that bracket and see if I can readjust without modifying the bracket.
  8. 1971CamaroGuy
    3,831
    200
    Oct 31, 2004
    Cool, let us know what you figure out
  9. Kris g
    115
    Jul 19, 2009
    Dennis, I think you were more right than me :)
    There seemed to be a slight dip in the one side. A couple washers to re-align the bumper and we were good to go! Looks good now.
    Kris
  10. BUSHY 409
    BUSHY 409 Veteran Member
    349
    Nov 25, 2006
    Acworth GA.
    are all the
    brackets of the same car >> 73 are high impack and stick out more .
